Spitfire Spitfire Windshield Frame Header
doates
Hello,
On my 70 Spit there is an aluminum cap that rivets to the top of the windshield frame. I vaguely remember there being some kind of sealant underneath this cap. Am I correct and can anyone tell me what it should be? Seems like a good place for a fat bead of silicone.
Also, there are two rubber plugs through this cap; do they attach to the aluminum or the frame below? Are they there to cushion the top header when it rests on the windshield frame?
Thanks in Advance
Dennis
dklawson
I would not use RTV between the aluminum and windscreen frame. If you ever want to take that part off in the future the RTV will make the task nearly impossible.
When I removed the cap on our car it had a non-hardening white caulk type material between the parts. I have seen similar caulk strip products in hardware stores. I didn't want to stick the parts together permanently so I used 1/4" wide strips of closed cell weatherstrip foam tape applied to the aluminum. So far it has held up well and water has not leaked in.
I remember that the rubber buttons were sort-of grommet like. I remember that they fit the aluminum plate. They are removed to access the through-holes used to bolt on a hardtop.
doates
doates
Thank You,
That makes since about gluing those two parts together. I will also try the insulation strips. I had no idea that is where a hard top bolts.
Thanks Again....Dennis
dklawson
So far I have been pleased with the foam strips (at least my sons appear to be... they have not reported any leaks). What I forgot to mention is that when I applied the foam strip to the aluminum, I only applied it across the front and sort of wrapped it back along the sides. There is no need to apply the seal all the way around as most of the plate is covered by the top when it is up and what you are trying to do is prevent water rolling up the windshield from finding its way between the windscreen frame and aluminum plate.
BRSLimited
Every one I have taken apart has been a really thick white body sealant that doesn't dry but is it ever a PITA to get off. I've used dum dum from auto body shops to put back in. I'll have to remember the weatherstrip idea. Probably much cheaper and less messy if it ever has to come apart again.
doates
doates
I installed the foam weather strip and I think that it will work well. The squishy closed cell foam squeezed down nice and tight when I installed the rivets.
A couple of tips that most of you probably already know:
1) The brass "keyholes" that go under the aluminum strip are handed. I had to drill out the rivets and reinstall.
2) Protect the aluminum strip from the broken off nail that is dying to scratch it when you snap the rivet. Two layers of masking tape was barely enough.
F Spitfire 1500 Spitfire Windshield Glass, Gasket and Install Triumph 12
J Spitfire Spitfire Windshield replacement Triumph 19
dklawson Spitfire Spitfire Windshield Installation - Mk4 Triumph 4
T Spitfire Spitfire windshield wipers getting old and slow Triumph 15
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
