Hap-- Exhaust manifold/header paint?
PAUL161
Hap, What's the best high heat paint you've used, if any, for exhaust manifolds or headers? Bill Hirsch has, <span style="text-decoration: underline">as advertized,</span> 1800 degree paint. Any others out there? Just checking. PJ
I used the VHT on trace headers, and can tell you it did not hold up, so I listening as well, 1800 degrees ought to do it, normal exhaust temps get around 1300 or so, so 1800 would be good. The first siz inches are so of a header or exahust manifold is the challenge, after that VHT stuff has held up.
PAUL161
PAUL161
Thanks Hap, I'm going to order the Hirsch 1800 degree paint. It's worth a try and if their 1800 degree statement is true and the exhaust temps stay around 1300 degrees, I would think it should hold up. If it doesn't, then I'll have it ceramic coated. I just didn't want to spend that much money on the manifold if I didn't have to. I'll probably go broke restoring this car as it is! :rolleyes: PJ
T Articles by Hap Waldrop reg engine disassembly and assembly Spridgets 1
BlueMax "Thanks Hap" Spridgets 5
Mickey Richaud MGB Thanks, Hap! MG 5
PAUL161 Carb rebuilder? Hap? MG 5
PAUL161 Question for Hap and Others. 140 hp XPEG? MG 1
Basil Happy Birthday Hap! MG 8
I How do I get a hold of Hap? Spridgets 2
Hap Waldrop Hap will be on track sooner than thought :] Racing 19
Scott_Hower Hap started my head... Yay! Spridgets 13
bugedd VTO wheel fit issues, help Hap! Spridgets 24
B Where's Hap? Spridgets 12
G Hey Hap, got $25 ??? Spridgets 16
PAUL161 Hap, Crane cams? MG 6
jmwuva05 Another one of Hap's masterpieces Spridgets 4
T Hap - some TR guys need rims from you Spridgets 1
T Hap - 175/70/13 or 185/70/13 for your Superlights? Spridgets 26
jmwuva05 Hap and my engine Spridgets 5
mccalebr Hap's engine build log Spridgets 7
DrEntropy For Hap and th' Day: MG 9
mccalebr Eye candy - Hap's HS2 carbs Spridgets 20
M 1275 Engine Rebuild - Especially Hap! Spridgets 11
PAUL161 Hap, Doc, Tony, have you heard of this stuff? Restoration & Tools 14
mccalebr Hap's 1275 engine builds for Ray and Drew Spridgets 15
T Hap, what is that thing...? MG 14
B Thanks Hap! Spridgets 3
jlaird Hap, I need help Spridgets 0
64rocksprite 12G295 question...Hap?? Spridgets 4
healeyboz New seats and Hap's Carbs Spridgets 14
jlaird Morning Hap Spridgets 0
jlaird Hap Spridgets 2
PAUL161 Got My HIFs Back from Hap. You were right Doc! MG 4
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 10
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
