TR2/3/3A Intake header crossover passage.....
K
karls59tr
Bronze
Shouldn’t be too dirty esp with carbon as it shouldn’t have burnt residue on the intake side.
but may be you could suck some string through using a vacuum cleaner and then pull a soaked rag through the cross over ?
When I pulled the cylinder head to address the blown head gasket (possibly F08 failure...can't determine that till Spring because of weather conditions here) I found that the inside of the intake manifold was just covered in carbon! There may be another issue going on in addition to the gasket problem namely a suspected broken chain tensioner and possible skipped timing chain tooth? Would the latter cause such a carbon build up?
Hamish Racing
I would have thought that carbon on the intake side suggests combustion before the inlet valve is closed - or opening just after ignition. But this would mean a distinct lack of compression.
i think this would cause carb flames/spitting back. So yes slipped timing chain may contribute to this issue
not our carbs but same principle video
P For Sale Weber carb/intake, header Spridgets Classified 2
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Failed intake manifold gasket? Triumph 2
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
shadowfever MGB MGB intake wanted MG 2
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale- TR-6 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale TR6 '69-72 Intake Manifold Stanpart V3108 Triumph Classifieds 0
steveg TR6 Fixing the intake manifold Triumph 8
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Michael Oritt Intake manifold question Austin Healey 11
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
steve00136 MGB Intake manifold alignment MG 4
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
Lin Intake manifold drain pipes Austin Healey 29
R FFuel overflowing at Intake Manifold Austin Healey 10
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
K For Sale TR3 Intake Manifolds..... Triumph Classifieds 0
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
H BJ8 blew out intake manifold plug Austin Healey 10
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
T SOLD!! Original AH 100 LeMans intake manifolds Austin Healey Classifieds 2
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
bugedd Carb/intake question Spridgets 6
bugedd Intake Manifold Spridgets 12
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
C TR2/3/3A Intake/Exhaust Manifold Replacement Triumph 11
R Air Intake Deflector - Radiator Austin Healey 8
E TR6 1973 TR-6 Unbalanced Intake Triumph 11
K Midget backfire at intake side... Spridgets 7
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
bugedd Weber intake manifold Spridgets 4
G TR4/4A Intake Manifold Question Triumph 6
TRMark TR4/4A Convert from H6 and log to HS6 and 4A intake Triumph 6
H Rad intake air deflector plates Austin Healey 6
S TR4/4A What attaches to the intake manifold Triumph 4
B New Intake Manifold Austin Healey 12
