Gasket Sealer on Intake/Exhaust Manifold Gasket.
BG 62AH
Doing some winter project work. Pulled the intake and exhaust manifolds off and found that when a previous repair was made, the mechanic used gasket sealer on both sides of the intake/exhaust manifold gasket. Not under my ownership.
I was planning on reassembling with a new gasket, but have never used gasket sealer on my TR6 i/e manifold gaskets.
Doesn't seem to be a reason for it, any suggestions or opinions appreciated.
Thank you.
Michael Oritt
Bill--
It may not be necessary but it can't hurt. I use Ultra-copper for high-heat applications such as this.
dklawson
Strictly speaking... I believe use of sealant on the manifold gasket is discouraged. However, on my Triumph engines I have used sealant on the manifold gaskets. That is because my Spitfire and GT6 have/had aftermarket headers that I could never dress flat.
dougie
Thank you.
I use Locktite Copper Hi-Temp gasket spray https://www.amazon.com/Loctite-37583-Temperature-Adhesive-Sealant/dp/B003XZARRK on both the exhaust and intake manifold on my race motors. It makes a solid seal and allows for easy removal.
B
BG 62AH
Guys, thank you. In reflection I like the idea of using a high temp sealer. Appreciated.
red57
In the late '60s when I was taking a vo-tech auto mechanic class I remember specifically being told not to use gasket sealers on these type gaskets - the asbestos-type side bonds to the head and waffled metal side is supposed to allow a small amount of movement/slippage due to the differing expansion rates of the head and manifold. So, I have always installed them dry.
Doing a little quick research I found the Moss has developed their own gaskets for their supercharger kits and specifically say leave them dry.
Fel-Pro site also specifically says to install dry.
Not too sure it makes a huge difference but thought I'd throw it out there. I think you have been doing it right all along.
Dave
C Exhaust/Intake gasket sealer? Austin Healey 4
B TR6 Gasket sealer Triumph 1
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
D TR2/3/3A OD cover plate gasket sealer. Triumph 17
T TR4/4A Head gasket sealer question Triumph 7
KVH General Tech Gasket Sealer and Sealants Triumph 6
S TR2/3/3A copper gasket sealer and push rods Triumph 10
S TR2/3/3A gasket sealer for the bear plate Triumph 7
M Water Pump Gasket & Sealer Spridgets 10
CinneaghTR Oil Pan Gasket Sealer? Triumph 14
V Valve cover gasket & sealer??? Spridgets 11
D Gasket sealer British Motor Corp 2
T TR6 TR6 water pump gasket - also use sealer as well? Triumph 9
B What Gasket Sealer to Use on Engine Parts? Spridgets 8
M Gasket sealer on bell housing to gear box Austin Healey 13
S Timing cover gasket sealer Spridgets 6
J Head Gasket Sealer Spridgets 9
L Does anyone use gasket sealer on the oil pan? Austin Healey 2
C Gasket Sealer Triumph 5
T TR6 TR6 water pump installation - use gasket sealer Triumph 7
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Failed intake manifold gasket? Triumph 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
RJS TR4/4A Fuel Pump Gasket Triumph 8
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KVH General Tech Permatex Aviation Form a Gasket; Permatex Ultra Gray Triumph 12
P MGB Zenith water choke gasket needed MG 4
T TR2/3/3A tr3 head gasket Triumph 38
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
DrEntropy MGB Head gasket R&R goes on... MG 13
tahoe healey Cork Gasket Prep Austin Healey 17
LAW75 Timing Chain Cover Gasket Austin Healey 12
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
