Header Question
JPSmit
Spring is coming and a young man's thoughts turn to cars. (as if they ever leave)
Ebay has a couple of Patriot Headers (including one from Summit) the flange thickness is listed as 5/16" - how does that compare to the intake manifold? I understand that the pace headers (among other issues) are too thin.
I do not know, but it is pretty easy to make stepped washers.
G
JP, from what I've heard there is little to no noticible gain from stock to a header on the 1500. Plus, you'll have more underhood heat too. Pacesetter is owned by Pertronix.
JPSmit
JPSmit
It's not really for gain. Mostly to clean up the exhaust system. gets rid of the remains of the Catalytic converter and, when I was reassembling the car the exhaust was touching the body so we got it bent - too far - so the whole exhaust hangs too low and the exhaust pipe is getting to its last legs so, am thinking that before the 50th even, I might get a header, stainless exhaust and of course the Harley Muffler. Actually the Patriot header is my second choice as I have an email out to see if I can source a Bell stainless one.
JPSmit
JPSmit
kellysguy said:
Stainless? Keep me posted! :wink:
you and your bling! :thumbsup:
Spridget64SC
We've measured numerous manifolds and header flanges to get things close in the racing world. 5/16" is the right thickness for A-series headers. Manifolds measure anywhere from 0.306 to 0.315" thick, depending upon casting number and type. We run into most of a problem when modifying MGB manifolds to go on the 1275. Sometimes TIG repairs and build ups and then machining down is required. Should not be a problem on a 1275 stock manifold.
Most cheapy street stuff has primary header pipes too short to make any real improvements. Primary pipe lengths should be in the 25"+ range to get any real torque improvements.
The only real cheapy method I've found to get around the high cost of an LCB for a Spridget from any USA supplier is to buy one for a Mini out of the UK and then cut and modify it for a Spridget. I've built tunnel exhaust systems for my race car doing it that way. If you have a MIG, a hacksaw and patience, that's the way to go. Use 0.023" wire in the MIG, buy a few extra 45's and 90's in mild steel from Summit/Jegs and start fabbing.
HTH,
Mike Miller
JPSmit
JPSmit
here is the answer
Thanks for the enquiry, sadly Bell do not make a stainless header for this car, they only offer a full system which would be ready in about 2-3 weeks.
:cryin:
D TR4/4A General header question Triumph 6
V early BN4 question - top & header rail Austin Healey 3
Coyote1 TR6 TR6 Header Rail Question Triumph 4
JPSmit Header Question Spridgets 2
drooartz Question: washers for header->manifold Spridgets 5
DrEntropy Header question: MG 6
C TR2/3/3A TR3 Header Question Triumph 10
bigbadbluetr6 TR6 TR6 original header question Triumph 3
jlaird Question - Exhaust header Spridgets 3
bigbadbluetr6 TR6 Another TR6 Header question Triumph 5
bigbadbluetr6 TR6 TR6 Header question part 2 Triumph 8
bigbadbluetr6 header question Triumph 9
K TR2/3/3A Using header wrap on a street car? Triumph 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Intake header crossover passage..... Triumph 4
CARSINC Please Identify this Exhaust Header Spridgets 2
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
JFS TR2/3/3A Exhaust Header Fitment Triumph 13
P For Sale Weber carb/intake, header Spridgets Classified 2
J For Sale Header, hub caps Spridgets Classified 1
M Muffler Options with Exhaust Header Spridgets 1
bugedd Free header Spridgets 0
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
Rut TR4/4A Header seal attachment Triumph 0
Rut TR4/4A Header seal Triumph 3
R TR6 tr-6 header Triumph 0
B Advice on Wooden Header and Side Trim Rails for a BJ7 Convertible Top Austin Healey 9
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
Joe Reed General Tech VHT Flame Proof Header Paint MG 17
tomshobby Header Rail Seal Spridgets 4
H TR4/4A Header Rail Assembly Triumph 2
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
Jim_Gruber Looking for header and rear BE Top bars Spridgets 18
N Recommend a header? Spridgets 4
D BJ7-8 header seal retainer Austin Healey 3
Boggsy64 MGB Three port exhaust header? MG 6
B TR6 TR6 decision on header/manifold/exhaust Triumph 4
B Header rail weatherstriping Austin Healey 6
G Long center branch header for 1500? Spridgets 0
L Tubular header to ss exhaust pipe Spridgets 12
johnrip Wedge TR7 pacesetter header connection to stock exhaust Triumph 2
JPSmit Header and muffler connected Spridgets 16
GBRandy Wedge TR8 Header Install Triumph 42
bthompson Hood header rail gasket Spridgets 9
glemon Best Glue for Header Rail Triumph 8
7 Spitfire Spitfire Header Triumph 6
tahoe healey header rail cover Austin Healey 0
DNK Header Bolts Triumph 17
mjobrien Top cross section at the front header / bow Austin Healey 0
doates Spitfire Spitfire Windshield Frame Header Triumph 5
