TR6 TR6 Header Rail Question
Coyote1
I've got the TR pretty much finished and pulled out the top frame to start cleaning it. Problem is, the header rail is loose and bent up where it is riveted to the side frames. I should be able to fix it but I am not sure how it is supposed fit.
Do they normally have some play or should they be solid to the rivets? Do they lay straight with the frames or at an angle?
Any info and or pics would be helpful.
hondo402000
I had the same problem with mine on the drivers side, I straightend mine out and welded it. Not sure its thats correct but thats what I did
Hondo
CalvinSG
Hi Larry,
I'm pretty close to you, down here Elk Grove. I re-did the whole top frame and installed a sunfest canvass top. Mine was loose also. So straighted mine but it will have a little angle to it. look at your windshield top cap and you will see the angle you will need. I took a hammer and peaned the rivit on a flat vise to tighten them up.
I also have a 74 1/2 TR6 but somewhat modified with an Ls1 V8
Here is a website I used for information to rebuild your top frame with good information.
https://www.buckeyetriumphs.org/technical/TR6Top/TR6SoftTop.htm
Cheers,
Calvin
Coyote1
Coyote1
Mounted the frame and lined everything up to get a good secure fit. Had to straighten a couple of bends then peaned the rivets as Calvin suggested. Sits good and tight. Now to get the thing sanded down for paint.
The website Calvin Rx is great.
cheseroo
When I put a top on mine I found the header was super floppy. I had an old VW input shaft laying around that had a convex end on it. I used that to peen the rivets and it worked perfectly.
B TR6 TR6 decision on header/manifold/exhaust Triumph 4
D TR6 TR6 Moss Header Triumph 7
E TR6 TR6 "Tuned" Exhaust Header Triumph 8
A TR6 TR6 header gasket ?? Triumph 10
A TR6 Headers --VS.--Stock header??? tr6 Triumph 32
bigbadbluetr6 TR6 TR6 original header question Triumph 3
bigbadbluetr6 TR6 Another TR6 Header question Triumph 5
bigbadbluetr6 TR6 TR6 Header question part 2 Triumph 8
bigbadbluetr6 TR6 TR6 Header Triumph 2
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
