Header Bolts
DNK
Anybody used these before
Brosky
Interesting concept. Why the clip and do you take it off before the final torque down of the bolt?
And who makes these?
startech47
The clip holds on the "D" shaped plate that fits on the lower hexagon. The "D" prevents rotation of the fastener when it hits the header.
Brosky
OK, that I can see and understand. Do you torque the bolts with contact only being on those three tiny points of bolt head bottoms against the clips?
DNK
DNK
After reading up on these,and yes it is winter Tom, I don't know if on a car that is not driven a lot they would be that special.
Everybody recommends several runnings and torquing before locking them in.
Will have to think about these a minute or so.
Paul, Google locking header bolts . You'll find several.
Platinum
Spend yer sheckles on new lifters/pushrods!
Kids.
*sheesh*
:jester:
Brosky
OK, but do you remove the clip before torquing them down?
DNK
DNK
Yes The clip is only put on at the final and last torqueage
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Yes The clip is only put on at the final and last torqueage[/QUOTE]
Put on or taken off??
DNK
DNK
Actually I was doing a little more research after you've ask SO MANY questions
Look here
Until final torque ,just the bolt. Then add the wing then the clip and your done.
OK How'd I do?
Platinum
Well.
I posit if ya buy a bunch of grade eight bolts, place 'em at the holes and POUND 'em in with a two-pound hammer, the threads will deform enuff to LOCK the fasteners in and ya got no worries!!! Kinda like the [censored]-house screws in high schools. One-way fasteners.
...until ya gotta remove 'em NEXT year. :devilgrin:
What's so bad about a little LocTite onna threads of normal fasteners?
Or is this mill gonna see racing speeds and revs? That's a kettle of a diff'rent colour.
Mickey Richaud
So, is there such a thing as "Snake-oil Engineering"? :whistle:
Platinum
So ya gonna go fer new lifters an' rods then? :smirk:
DNK
DNK
the lifters and cam only have 1000 miles on em.
Prolly do the rods I want to measure em for correctness
K TR2/3/3A Using header wrap on a street car? Triumph 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Intake header crossover passage..... Triumph 4
CARSINC Please Identify this Exhaust Header Spridgets 2
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
JFS TR2/3/3A Exhaust Header Fitment Triumph 13
P For Sale Weber carb/intake, header Spridgets Classified 2
J For Sale Header, hub caps Spridgets Classified 1
M Muffler Options with Exhaust Header Spridgets 1
bugedd Free header Spridgets 0
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
Rut TR4/4A Header seal attachment Triumph 0
Rut TR4/4A Header seal Triumph 3
R TR6 tr-6 header Triumph 0
B Advice on Wooden Header and Side Trim Rails for a BJ7 Convertible Top Austin Healey 9
D TR4/4A General header question Triumph 6
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
Joe Reed General Tech VHT Flame Proof Header Paint MG 17
tomshobby Header Rail Seal Spridgets 4
H TR4/4A Header Rail Assembly Triumph 2
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
Jim_Gruber Looking for header and rear BE Top bars Spridgets 18
N Recommend a header? Spridgets 4
D BJ7-8 header seal retainer Austin Healey 3
Boggsy64 MGB Three port exhaust header? MG 6
B TR6 TR6 decision on header/manifold/exhaust Triumph 4
V early BN4 question - top & header rail Austin Healey 3
B Header rail weatherstriping Austin Healey 6
G Long center branch header for 1500? Spridgets 0
L Tubular header to ss exhaust pipe Spridgets 12
Coyote1 TR6 TR6 Header Rail Question Triumph 4
johnrip Wedge TR7 pacesetter header connection to stock exhaust Triumph 2
JPSmit Header and muffler connected Spridgets 16
JPSmit Header Question Spridgets 2
GBRandy Wedge TR8 Header Install Triumph 42
bthompson Hood header rail gasket Spridgets 9
glemon Best Glue for Header Rail Triumph 8
7 Spitfire Spitfire Header Triumph 6
JPSmit Header Question Spridgets 9
tahoe healey header rail cover Austin Healey 0
mjobrien Top cross section at the front header / bow Austin Healey 0
doates Spitfire Spitfire Windshield Frame Header Triumph 5
PSJ Hardtop front header seal Spridgets 4
T Back to original, cast iron header. Triumph 16
T Need exhaust header advice/source for Amos Triumph 49
PAUL161 Hap-- Exhaust manifold/header paint? MG 2
drooartz View of the header faces Spridgets 47
RJS Header/ Exhaust Manifold Wrap Triumph 2
drooartz Question: washers for header->manifold Spridgets 5
This14u Spitfire 1500 Spitfire Header Recommendation Triumph 0
