BJ8 muffler on a BJ7?
DickN
Member
I am attempting to reduce the the noise on my BJ7. Can the rear BJ8 muffler be added? If not any other suggestions?
Dick
Patrick67BJ8
Dick
The rear resonators of BJ8's would require you to "lift" the back of the chassis area for more ground clearance. Just lifting that area will not guarantee you that the resonators won't drag because they still do on BJ8's. Maybe someone will chime in on a quet earlier Healey muffler system?
rjc157
11-DFDAAD6D-1692809-1280-100.jpgif you have any interest let me know Monza exhaust with added wallker mufflers
5
57_BN4
The BT7 I am working on presently was so noisy I had to put my fingers in my ears- and it has a stock exhaust system (NOS, fitted >20 years ago). The muffler has lost all it's glass packing and is now completely ineffective so I am refitting another NOS muffler this week.
If you have an original style glasspack then maybe it just needs replacing due to lost material?
British_Recovery
Bronze
Early BJ8 cars (Phase 1) had the rear resonators even though the frames were the earlier style like the BJ7. Increasing rear ground clearance would be helpful, though. I've had good luck with just replacing the main leaf on standard Healey springs with one slightly thicker. A good spring shop can do this.
Good luck, Bob
S BJ8 muffler system Austin Healey 3
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
