TR2/3/3A The horn and turn signal assembly.
karls59tr
Bronze
The turn signals have stopped working and I know it's an issue this assembly. I have had the long wiring tube out before and I am familiar with the grub screws an how the long tube slots into the stator tube. Looking at the back of the horn button assembly there is a moveable plate with a 2 pronged extension on it. I believe this extension is to be situated 180 degrees from the turn signal switch. On the grey metal part behind the plate there looks like a groove that is either a "stop" for that extension piece or maybe the extension piece is supposed to fit in that groove and i assembled it wrong the last time I was in there??? Does anyone have a picture of this area and also a link to the assembly dismantling ? Thanks Karl
mctriumph
TRF sells an excellent replacement assy ,These beasts are in my experience nearly impossible to re-build as
far as not having to FIAT very soon(fix it again Tony).
MD
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
J Horn/turn signal rotate independently of the steering wheel. FORUM Navigation Questions 1
I TR2/3/3A Horn, Turn Signal Switch Triumph 2
M Need help with horn/turn signal unit Triumph 18
Got_All_4 Weird R&R the turn signal switch and horn blows Triumph 8
F TR2/3/3A TR3 Turn Signal/Horn control head Triumph 4
Lin Trafficator, control head, turn signal switch/horn Austin Healey 5
K 68 midget. No horn, headlights, turn signals Spridgets 9
jjbunn E-Type Turn Switch - loose braid for horn? Jaguar 6
ekamm TR2/3/3A TR3a horn/turn indicator control head Triumph 13
P TR6 Horn issue 1974 TR6 Triumph 5
P TR2/3/3A TR2 Horn Mounts Triumph 7
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
R Horn relay Spridgets 2
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
P TR6 TR6 Horn Relay Problems Triumph 8
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
K Restoring Horn Push Button Austin Healey 12
Jim_Gruber Intermittent Horn Spridgets 2
Joe_Healey TR5/TR250 Bubba Horn Triumph 0
G TR4/4A Horn Brush Question Triumph 7
