Horn question follow up
Why use a relay for horn? I have installed a Charlie Hart seven fuse unit, with one fuse dedicated to the horns. Is there any reason to install a relay unit in the horn wiring? My new horns came with one, but I’m not sure I need it.
Once again, many thanks!
Larry (again)
steveg
Larry (again)
Sounds like needless complexity.
longbridgehealey
It did to me too, and I was hoping you would agree👌. And you were right, there was a bare wire grounding the system on the horn circuit, which was not in the trafficator.
Michael Oritt
Not using a relay means that every part of the circuit(s) must carry the full amperage load, from the power lead to the horn button all the way to the horn itself. i don't know what kind of horns you are using but loads of 5 to 15 amps per horn are common, and wire to carry that load is relatively heavy--I'm guessing that 14 to 16 AWG is probably what would be specified.
OTOH using a relay allows the use of lighter wires on the circuit that activates the relay as that wire will only carry the load required to actully activate and hold the relay closed, which might be only a couple of amps. And if the relay is located close to the horn(s) the run for the heavy wires can be kept short.
steveg
One could argue, in the case of the horns, the wires are used very seldom, and for a very short interval - too short to heat up.
Also there's a separate wire for each horn. Mine mainly get used when I tilt the driver's seat forward.
GregW
The fused wire for the horn is as short as it can be going from the fuse straight to the horn. putting a relay in that line makes no sense. The horn button on the steering wheel is for the ground wire.
Michael Oritt
It doesn't matter whether it is the ground or the hot wire--if current flows through it the considerations are the same.
Michael Oritt
Or use this--nothing needed at all:
healeyblue
I agree with Michael. If the horn did not use a relay then the wire for the button would have to be a larger gauge (even if it is on the ground side) and there is limited room for the wires to run up the traficator tube as it is. Adding girth for a larger wire only worsens the situation.
Keoke
OTOH using a relay allows the use of lighter wires on the circuit that activates the relay as that wire will carry only the load required to actually activate and hold the relay closed, which might be only a couple of amps. And if the relay is located close to the horn(s), the run for the heavy wires can be kept short.
True statement !
John Turney
Same here. The wire sizes shown in charts assume the wire is in continuous operation, such as running a motor. Operating for short intervals allows smaller wires. For example, until engineers figured out that the starter would operate for only short intervals, the wire sizes suggested by the charts made starters too bulky.
RAC68
Keoke,
Your statement presents why I installed relays on my upgraded head and driving lights. The relays are fed by a higher gauge line and connected to the main power line from the battery/starter/alternator-generator. Although I do agree that my low use of the horn (averaging less then once a year) and since the circuit is separate (hones alone) and fused, I see little reason to further complexify the horn circuit.
My thoughts,
Ray(64BJ8P1)
G Follow-Up Horn Question Triumph 2
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
Bayless Question on '67 horn button Spridgets 5
longbridgehealey 100-6 BN4 horn question Austin Healey 2
G TR4/4A Horn Brush Question Triumph 7
JPSmit Question three - horn - electricery Spridgets 12
Gerry M TR6 Horn Relay Question Triumph 4
bugedd Horn Question Spridgets 30
longbridgehealey bought a 69 Sprite, gotta horn question Spridgets 11
drooartz Another horn question Spridgets 5
JPSmit horn question Spridgets 2
TR4 Horn replacement question Triumph 7
1965_MGB MGB MK1 MGB Horn Contact Question MG 0
B TR6 Horn Assembly Question 74 TR6 Triumph 2
P TR6 Horn issue 1974 TR6 Triumph 5
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A The horn and turn signal assembly. Triumph 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
R Horn relay Spridgets 2
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
P TR6 TR6 Horn Relay Problems Triumph 8
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
K Restoring Horn Push Button Austin Healey 12
Jim_Gruber Intermittent Horn Spridgets 2
