cityslicks
Putting in a new horn control unit. When I pulled the stator tube out of the steering column I found the control unit was welded to the stator tube. Is that the way it is suppose to be? Seems like to me that after pulling the new wires down the tube and then welding the unit on the stator tube the heat of welding would melt all the wires inside. Is there some resource available that details how to replace the control head?
