Question on '67 horn button
Bayless
Among the many boxes of parts, I finally found the steering wheel and later the horn button. They seem to match up and look like the pictures in Horler. The problem, I have not found any of the in-between stuff that mates them together and the Haynes manual and Moss catalog doesn't give any help. Does anyone have pictures or even remember how to describe what I should be looking for or what I might have to make. This is a photo of the back of the button.
nomad
You should be looking for a copper plated cup that bolts beneath the nut that holds the steering wheel and that your horn push will lock onto. Also a spring and a contact that comes out of the hollow center of the steering shaft. The brush that is in the middle of the steering shaft is the critical bit. Everything else I'm sure you could find used. Seems like I have the cup and spring but haven't a clue where.
Kurt
Bayless
Bayless
Thanks Kurt. I have the center contact and I think I found the spring. I was guessing something similar to the cup you described. I have since been through all the remaining boxes and found nothing that seemed related except that spring. Nowhere else to look for the cup other than try to make one now.
nomad
I think I would try some of the used parts places first. The ones that regularly sell on E-bay. I can do a search of my stuff as well. Not a simple thing to make since the three tabs on your horn push have to turn to lock into it and then be able to be pushed up and down without coming out. Also your horn button needs to be indexed correctly after everything is assembled.
Kurt
Bayless
Bayless
Ebay is a possibility. I do understand your concerns on trying to make one and I have plenty of other stuff that I should be doing instead. If you get a chance to see if you have a spare I would really appreciate that. Meanwhile, I will start checking ebay and such.
nomad
I looked in the place where I expected it to be with no success. I'll look some more.
Kurt
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
G TR4/4A Horn Brush Question Triumph 7
JPSmit Question three - horn - electricery Spridgets 12
Gerry M TR6 Horn Relay Question Triumph 4
bugedd Horn Question Spridgets 30
longbridgehealey bought a 69 Sprite, gotta horn question Spridgets 11
drooartz Another horn question Spridgets 5
G Follow-Up Horn Question Triumph 2
JPSmit horn question Spridgets 2
TR4 Horn replacement question Triumph 7
1965_MGB MGB MK1 MGB Horn Contact Question MG 0
B TR6 Horn Assembly Question 74 TR6 Triumph 2
K TR2/3/3A Cylinder head stud height question? Triumph 2
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
