MGB MK1 MGB Horn Contact Question
1965_MGB
Greetings All,
I am working on the column I got back recently from Gerry, and I have a question. I am replacing the contact ring, and I was wondering what the easiest way to slide the brass ring might be.
I am not sure if it is going to be easier to slide the brass ring up or down over the rubber part. I am concerned about bending the tabs, so if someone has done this, and might have some insight, it would be greatly appreciated.
I have enclosed a picture of what I am working with to help illustrate.
Todd78d Sprit MK1 gear box filler Spridgets 2
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
K MK1 Cooper S? British Motor Corp 3
M General MG Midget MK1 windshield replacement MG 2
K Disc Brake Conversation to MK1 Midget Spridgets 2
D AH 300O MK1 Choke Knob Position Austin Healey 5
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
LarryK Jaguar MK1 restorations Jaguar 15
B 1959 mk1 3.4l jag Jaguar 4
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
R For Sale MK1 hardtop B pillar clips, reproduction part Spridgets Classified 4
S XJ6 Mk1 clutch slave question Jaguar 0
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
Csarneson Bargain 3000 Mk1 in Colorado Austin Healey 1
A Mk1 rear deck restoration Spridgets 0
A Chassis front 'H-section' Mk1 Spridgets 5
D Charging issue on mk1 British Motor Corp 1
A When were turn signals original equipment on Mk1 Bugeye Sprites? Spridgets 4
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
R GT6 Mk1 Pulley weighting marks Triumph 6
A Newbie Bugeye Sprite Mk1 owner looking for some advice Spridgets 49
C MK1 3000 fan belt Austin Healey 1
B GT6 Mk1 GT6 glass domed fuel pump Triumph 6
K 61 Mk1 auto to manual OD gearbox swap? Jaguar 0
N Bulb holder Mk1 3000 Austin Healey 5
M signal lamp replacement - 1960 austin-healey 3000 mk1 Austin Healey 6
C Mk1 3000 screen/windshield fitting Austin Healey 7
A Mini Mk1 dash heater knob British Motor Corp 0
C Servo fitting MK1 3000 Austin Healey 1
C Mk1 3000 side screens variations Austin Healey 13
C Healey 3000 Mk1 engine Vs Wolseley 6/110 Austin Healey 18
D MK1 Rubber Tunnel Cover Spridgets 3
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
ShawnC_at_Moss Spitfire New catalog includes Spitfire Mk1, 2 & 3 Triumph 6
RickB MK1 Midge radiator value? Spridgets 2
I 2000 MK1 posted on CL Triumph 2
dklawson GT6 Head Re-Torque - Mk1 GT6 Triumph 8
S MK1 midget measurements Spridgets 0
brgrmyster GT6 New Molded Carpet Set GT6 Mk1 & 2 For Sale Triumph 7
Boink Color Wiring Diagram for Mk1 Spridgets 8
C Trick Midget Mk1 Racecar Spridgets 15
Eddie6775 GT6 Installing Fiero seats in My GT6 MK1 Triumph 24
dklawson GT6 Mk1 GT6 Engine Rebuild Triumph 36
brgrmyster GT6 Anyone Parting a 67-68 GT6 Mk1 US spec Triumph 2
brgrmyster GT6 NOS Lucas heater fan switch 35560 - 67/68 GT6 Mk1 Triumph 2
K MK1 Seat Repair/Rebuild Triumph 5
C Some cool Pics of my MK1 Spridgets 25
J Fiberglass Fenders for Early Midget MK1 Spridgets 11
