Trick Midget Mk1 Racecar
Boink
Bronze
Nice car!
jlaird
Good stuff.
aeronca65t
Nice!
I have the same 2X4 dead pedal in my car.
It's interesting to read that he uses 1st gear at Watkins Glen. In my stock, wide-ratio box, I hardly use 3rd at The Glen.
G
CurtisJ said:
Do you ever - maybe just for a moment - imagine your Spridget is a racecar?
I have no such delusions whatsoever. :wink:
aeronca65t
58Custom said:
Why the 1/4 elliptic springs?
There's a point of view that says the earlier cars with 1/4 elliptic springs offer greater axle control. And perhaps, in a theoretical sense, they do.
Honestly, I've raced Spridgets with 1/4 and 1/2 elliptic and at least in my view, they aren't much different (assuming good tires, panhard rod, etc).
I've also driven and owned street Spridget in both styles. Again, if in good condition, they aren't a lot different.
I beg to differ ... on a street car there is a huge difference in the 1/4 elliptical and the semi elliptical. In a nutshell the semi's are a much better ride, but not as predictable in corners. The 1/4's ride like crap, but are very predictable.
nomad
I agree with Trevor. Like the handleing of the BE the best but don't like the problem I have with bottoming out I seem to have with the BE. Chuck holes mainly but my back ain't in the best shape. Anyone have a good overload spring set up for a 1/4 car??
Kurt.
jlaird
Back in the day. About 1965 my Bugeye could and did beat any square body, PERIOD.
Race after race, month after month, quite fun actually.
If it is bottoming out frequently, then the springs are probably worn out. I installed a set of "rally spec" springs, but I removed a few leafs and wedged them so that I have a stock ride height and similar spring rate.
Let me rephrase my statement: MY 1/4 elliptical spridget rides much worse than MY semi-elliptical spridget. :smile:
nomad
Actually my BE has very low miles and the springs look like new. When I got the car a previous owner had apparently slid into something and the car 'dog tracked'. I completely disassembled the springs, cleaned them and repainted them while I was curing the 'dog-track'. I'm thinking the original's were a bit soft which I don't mind. I just don't like the limited travel and the pain associated with bottoming them!
I'm thinking of drilling a large hole in the rubber block that is the current stop and inserting a stiff coil spring to take up some of the force before it contacts the block.
Kurt.
I considered all sorts of fixes, but in the end I purchased new springs. Then I experimented with all sorts of leaf combinations until I found what seems correct. My car will still bottom out on occasion, but it takes a pretty substantial bump. They might be a bit stiffer than original, but I'm certainly not feeling every pebble in the road.
jlaird
Should not bottom out. I have never in over 30 years had it happen. Autocross, track racing, street racing, and off road. Yep off road.
I suggest your springs are week or something. Should never bottom.
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
Basil Neat trick for reading oil level Restoration & Tools 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
N TR2/3/3A Cheap trick Triumph 5
Graham H TR2/3/3A Randall's Trick Triumph 10
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
S Ramps. What's the trick? Spridgets 23
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
Got_All_4 TR5/TR250 Rope trick on a broke valve spring Triumph 8
S Trick or Treating Spridgets 5
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
S So, what's the trick... Spridgets 17
T TR6 tr6 water pump trick? Triumph 4
H Trick needed - for body curve Austin Healey 12
Henson80MGB Trick to remove rubber hose to Slave Cylinder? MG 19
P help: trick to snap and unsnap soft top ? Triumph 11
glemon 11/64s drill bit tranny mounting trick Triumph 10
M Weber Carb trick Spridgets 1
BOBBYR Trick question . See what you think. Austin Healey 10
W A neat trick Spridgets 1
Jim_Gruber Rinstalling Beehive Lamps on BE what is the trick Spridgets 7
RickB Any trick to replacing shackle bushings? Spridgets 5
J What the trick to the steering column bushes? Triumph 6
jlaird Very slick trick Spridgets 3
zimmy my new clutch bleeding trick Spridgets 10
Jim_Gruber Removing Aluminum Channel on top of door - Trick? Spridgets 5
W New or another ebay fraud trick Triumph 8
jlaird For my next trick Spridgets 5
J So what is t he trick for getting the ujoints out? Triumph 3
J Any trick to getting the bump stops off Triumph 14
P Nut and wire Trick Triumph 9
E TR6 TR6 Front Suspension... Is there a trick? Triumph 8
aeronca65t MGB Semi-trick MGB MG 7
G Out with the rubber-hose-to-the-ear trick..... Triumph 10
RobSelina what's the trick to getting a steering wheel off? Spridgets 36
tomshobby Kind of a neat trick. Triumph 4
aeronca65t Trick Pontiac GTO Other Cars 3
A Spitfire Trick to remove 78 Spit carb? Triumph 4
G Neat trick Triumph 5
Alan_Myers TR2/3/3A TR2/3/4 cooling trick? Triumph 1
Z Rope trick works! Triumph 10
J Exhaust Valve - dollar bill trick! MG 20
Steve Secret door trick MG 1
Basil Rope Trick Triumph 2
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
