Mk1 rear deck restoration
AlFresco
Member
My Frogeye has its rear deck cut back a la Mk2+ but not particularly elegantly.
Despite the improved boot space access, I'm looking to reinstate the missing section. I can see the points where there was a brace under the deck but getting the right curvature upon which to apply the bespoke panel is the concern.
I believe there are probably a number of Mk1s out there with this mod and others that might have had it reversed. I'm hoping a brace may be available somewhere or at least some measurements.
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
B Lights in rear bin pockets early MK1 Mini Minor British Motor Corp 4
B Spitfire Spitfire Mk1 Rear Anti Roll Bar / Sway Bar Triumph 3
B Spitfire Spitfire Mk1 Rear Spring Shape Triumph 7
Todd78d Sprit MK1 gear box filler Spridgets 2
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
K MK1 Cooper S? British Motor Corp 3
M General MG Midget MK1 windshield replacement MG 2
K Disc Brake Conversation to MK1 Midget Spridgets 2
D AH 300O MK1 Choke Knob Position Austin Healey 5
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
LarryK Jaguar MK1 restorations Jaguar 15
B 1959 mk1 3.4l jag Jaguar 4
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
R For Sale MK1 hardtop B pillar clips, reproduction part Spridgets Classified 4
S XJ6 Mk1 clutch slave question Jaguar 0
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
Csarneson Bargain 3000 Mk1 in Colorado Austin Healey 1
A Chassis front 'H-section' Mk1 Spridgets 5
D Charging issue on mk1 British Motor Corp 1
A When were turn signals original equipment on Mk1 Bugeye Sprites? Spridgets 4
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
R GT6 Mk1 Pulley weighting marks Triumph 6
A Newbie Bugeye Sprite Mk1 owner looking for some advice Spridgets 49
C MK1 3000 fan belt Austin Healey 1
B GT6 Mk1 GT6 glass domed fuel pump Triumph 6
K 61 Mk1 auto to manual OD gearbox swap? Jaguar 0
N Bulb holder Mk1 3000 Austin Healey 5
M signal lamp replacement - 1960 austin-healey 3000 mk1 Austin Healey 6
C Mk1 3000 screen/windshield fitting Austin Healey 7
A Mini Mk1 dash heater knob British Motor Corp 0
C Servo fitting MK1 3000 Austin Healey 1
C Mk1 3000 side screens variations Austin Healey 13
C Healey 3000 Mk1 engine Vs Wolseley 6/110 Austin Healey 18
D MK1 Rubber Tunnel Cover Spridgets 3
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
ShawnC_at_Moss Spitfire New catalog includes Spitfire Mk1, 2 & 3 Triumph 6
RickB MK1 Midge radiator value? Spridgets 2
I 2000 MK1 posted on CL Triumph 2
dklawson GT6 Head Re-Torque - Mk1 GT6 Triumph 8
S MK1 midget measurements Spridgets 0
brgrmyster GT6 New Molded Carpet Set GT6 Mk1 & 2 For Sale Triumph 7
Boink Color Wiring Diagram for Mk1 Spridgets 8
C Trick Midget Mk1 Racecar Spridgets 15
Eddie6775 GT6 Installing Fiero seats in My GT6 MK1 Triumph 24
dklawson GT6 Mk1 GT6 Engine Rebuild Triumph 36
brgrmyster GT6 Anyone Parting a 67-68 GT6 Mk1 US spec Triumph 2
brgrmyster GT6 NOS Lucas heater fan switch 35560 - 67/68 GT6 Mk1 Triumph 2
