General MG Midget MK1 windshield replacement
Msroyalerp3
Good Evening everyone. I recently bought a Midget MK1 as a restoration project. Currently replacing the rubber on the windshield. I have replaced the seal between the frame and body. Any tricks or tips for replacing the seal around the glass? Appears that the frame is all one piece unlike the later MKII windshield frame. Thanks!
Platinum
Could you post a couple photos of the windshield? Detailed ones of the lower corners would help.
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
K Disc Brake Conversation to MK1 Midget Spridgets 2
S MK1 midget measurements Spridgets 0
C Trick Midget Mk1 Racecar Spridgets 15
J Fiberglass Fenders for Early Midget MK1 Spridgets 11
scoutll Rivergate Conversion on a MK1 Midget?? Spridgets 21
J Midget MK1 Shock Conversion Spridgets 7
jvandyke MK1 Midget CL, good price Spridgets 2
Ohiobugeye Bugeye vs. Sprite Mk2 / Midget Mk1 Starter Cable? Spridgets 20
Monark192 Mk1 Midget hard top question? Spridgets 9
Morris Midget MK1 fuel tank in a 1500? Spridgets 24
6 Holes in a Midget Mk1: Help! [confusing] Spridgets 1
I MK1 Midget [948] water leak MG 1
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
