100-6 BN4 horn question
Hi everyone. Here’s my question of the week. When the Healey arrived in Florida a few years ago and took its first outing the horn suddenly came on as I was driving along. Repeated pressing of the horn push had no effect, so I disconnected the bullet plugs behind the grill. Reconnect, horn blows. So my understanding of how the horn works is that it is always a hot circuit and when the horn push is depressed it pushes a plate down against a spring and makes contact with a contact plate, creating the circuit ground. If this is correct, then the most likely cause of my problem would probably be unintended grounding of the circuit somewhere in the wiring. Am I right? Should I start at the trafficator? Am I making any sense?
Thanks!
Larry
steveg
Larry - a friend had this exact problem. He had somehow caused a short inside the wiring harness that passes thru the column. With the insulation gone he'd hit a bump and the horn would sound. With the bullets disconnected you should be able to see continuity between the brown/black wire and ground. Doubt the problem is in the horn button. If you get the continuity, you'll need to replace the trafficator harness. Not expensive. Great picture info on www.healey6.com.
This subject has come up before, so check the archives for more info.
longbridgehealey
Thanks, Steve. Going after it tomorrow or Sunday, we’ll see what happens. Also looking at Healey6.com Thanks again.
richberman How to connect horn wiring 57 100/6 BN4 Austin Healey 2
A 100/6 BN4 Restoration Austin Healey 7
A 100/6 BN4 Door Lock Austin Healey 15
C 100/6 BN4 Soft Top Frame Austin Healey 16
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
G Wanted AH 100-6 BN4 Steering Wheel Austin Healey Classifieds 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
L 100/6 BN4 Brake fluid Austin Healey 17
L 100/6 BN4 Hood fittings Austin Healey 5
L 100/6 BN4 Fuel Tank feed Austin Healey 5
B Austin Healey 100-6 Bn4 Badge Number Austin Healey 17
madhouse 1958 100-6 VIN check [BT7 vs BN4] Austin Healey 7
V 100-6 BN4 door seals Austin Healey 8
V 100-6 BN4 side curtains - questions Austin Healey 6
H 59 100-6 bn4 Austin Healey 2
Johnny Is a BN4 a 100 six? Austin Healey 10
andrea WIRING DIAGRAM for imprved BN4 100/6 and early BN7 Austin Healey 3
N longbridge bn4 100/6 tonneau bar brackets Austin Healey 4
longbridgehealey carpet installation 100-6 BN4 Austin Healey 2
andrea Colors coded Wiring Diagram for 100/6 BN4 1956-58 Austin Healey 2
andrea DEFROSTERS AH 100/6 BN4 Austin Healey 2
ronzet New Seat Backs 1958 100-6 BN4 Austin Healey 8
N BN4 100-6 WIND DEFLECTOR INFORMATION Austin Healey 0
longbridgehealey 100-6 BN4 longbridge mirror Austin Healey 4
longbridgehealey top frame for 100-6 BN4 Longbridge built Austin Healey 6
bighealeysource aluminum trim piece for 100-6 BN4 door seal Austin Healey 2
bighealeysource 100-6 BN4 dash covering Austin Healey 2
C 59 100-6 BN4 value Austin Healey 8
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
