Turn signal beeper.
Nelson
When I am out for a drive I frequently would forget to turn off my turn signals. In club drives I have had the car in front of me also forget to turn off the blinking lights. Now I never forget to turn off my blinker anymore. I installed a 12 volt beeper that is a loud reminder that my turn has been completed. It is connected to the wire that goes to the dashboard blinking light. After making use of this system for a while I realized that I could mute the beeper while I am stopped and have the brakes activated, When I resume moving the beeper comes back on to serve as a reminder. I wired a relay between the beeper and the wire from the dash blinking light. The relay is activated and the beeper is disconnected when the brakes are applied. The wire that goes to the brake lights supplies the 12 volts that activate the relay.
Boink
Bronze
I did the same and it works well. The key, of course, is that the electronic chime must draw a very low amount of power so-as to not foul the mechanic (bi-metallic) flasher.
Not sure I follow your modification though... and I'm not fully understanding why the modification (with the brakes).
Nelson
Nelson
My beeper is rather loud and is annoying when I am stopped at a light or waiting to turn. Now I can enjoy the sounds of silence while I am stopped. And of coursr I can enjoy the sound of my exhaust.
Boink
Bronze
Ah, now I see. Yes, mine seems a bit loud while waiting as well.
Jim_Gruber
Rut,
That's the sound of a nicely built 1275. Sounds quite nice with my Harley Sportster Muffler.
Bill Young
I have done several modifications to the lamps on my Bugeye. Take a look at this diagram and perhaps you may get some ideas. A bit technical in ladder logic format.
  • Sprite Hazard rev B LED.pdf
Boink
Bronze
Very nice!
Nelson
Nelson
I had a head start on part of your items, Bill. I installed a four way flasher back in the early 60's. That was before they came in all the regular cars. I bought my commercial unit in a local parts store and installed it then. Currently I have a third brake light mounted on my roll bar to be as visible as I could make it. This LED light has two options in the way it functions. One way it operates is to flash the bank of LEDs rapidly when I hit the brakes. The other option and the way I am using it is to have the lights to blink sequentially from right to left and then left to right. It is like the TV car "Kit." Either way is a good attention getter.
Bill Young
Nelson. You did get a head start on 4 way flashers. almost 60 years ago !! Cheers
Boink
Bronze
nomad
I like the job of reaching for the middle of the dash for that turn signal toggle. After I drive the bug eye a while I find myself reaching for the middle of the dash in every vehicle I get into!:smile-new:
Seriously, makes me wonder if self canceling turn signals were all that much of an advancement.
I've purchased a licence plate surround with bright red LED lights that I wired into the brake light circuit. They add a little more notice to followers without having to do any modifications to the car.
Kurt
Boink
Bronze
I should really do that. Easy I'd think.
nomad
Yes, and I was going to give a link to the item on Summit racing but their site has become a tower of Babel with trying to manipulate their search engine. Couldn't find them.
Kurt
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
J LED Brake / Turn Signal Austin Healey 4
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
M Turn signal problem Austin Healey 3
R MGB Turn signal help 67 MGB MG 2
J Horn/turn signal rotate independently of the steering wheel. FORUM Navigation Questions 1
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
A turn signal knocked off center Austin Healey 14
D TR2/3/3A Turn signal cancel? Triumph 11
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
glemon TR5/TR250 Turn Signal Wont Blink Triumph 1
