Turn signal issues
bighealeysource
Bronze
Hey all,
having some gremlins with my turn signals on BN2/100M. Trafficator works fine but occasionally the right turn signal does not work where left does but sometimes neither side works ! Other times it works just fine so not the bulbs but thinking it could be the flasher relay on the left interior fender. Of course, it is under the cold air trunking which means taking it off so before I do that, can the original relay be serviced any - like clean up contacts -or should I just look into replacing it with a new one from Moss ?
Thanks
Mike
I took ours apart; IIRC it's sealed with spot welds and you'll need to use screws to get it back together. There are a couple relays inside and, also IIRC, they can be cleaned up in the usual fashion (points file, etc.). The replacements don't have the Lucas logo, but you could probably transplant the covers.
But, before you open it up, exhaust all other possibilities; esp. corrosion in one of the connectors or a socket. I took ours apart due to a turn signal issue, and after all the trouble found out the problem was caused by a mis-labeled harness wire. I don't think the problem is the flasher because it wouldn't have the left/right symptom.
Jack T
Since the flasher unit is relatively inexpensive and accessible, I would replace it before messing with the relay unit. After cleaning the connections as Bob suggests.
roscoe
I'd check the bullet connectors closest to where the steering column harness exits the steering box. Remove an reseat, clean if necessary. The other stuff is way more work.
bob hughes
Just slacken off the screws on the terminals at the relay and waggle the fork connectors re tighten and try that, if it works then take them off one by one and clean everything properly and put it back together with Vaseline or similar - worked for me without going into the relay box.
:cheers:
Bob
bighealeysource
bighealeysource
Bronze
Hey guys,
Did what Roscoe and Bob recommended and we have both lights working now all the time !!!!! At least for now since it is a Healey and may decide on its own for one to stop when a judge comes by to check her out - exactly what happened at recent Atlanta Concours. Oh well, at least another 100M took best in class.
Thanks
Mike
Kleykamp TR2/3/3A Still fighting turn signal issues. Triumph 1
T 100 Turn Signal Issues Austin Healey 1
QuickSilver MGB 77 MGB - Turn Signal, Brake Lamp and Hazard Issues MG 22
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
J LED Brake / Turn Signal Austin Healey 4
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
M Turn signal problem Austin Healey 3
R MGB Turn signal help 67 MGB MG 2
J Horn/turn signal rotate independently of the steering wheel. FORUM Navigation Questions 1
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
A turn signal knocked off center Austin Healey 14
