Air Deflector Assembly Hardware Help Request
hmsevans
I am in the process of putting my 1966 BJ8 together.
Need help in Two areas,
The Radiator Air Deflector Panel attachment to the Upper front Grille Panel ,One Fastener on each side
Also the Inner front wheel SPLASH PANELS attachment to the inner fender, 4 places, each side.
What are the correct Orig Fasteners, size,Type and direction and from which side.
Can not find any photos in the books and its so rainy here in the Northeast nobody has their cars on the road,
Thanks in advance,Mark
Johnny
Hello Mark, I don't want to discourage you but installing the radiator deflectors to the grill assembly was probably the most frustrating part of my resto. Somehow you have to cram the deflector brackets, the inner grill teeth and the outer trim ring to a set of three brackets mounted to the shroud, real fun :nopity:
To answer your questions, the two deflector shields mount to the fender wells with #8 buttonhead SS sheetmetal screws. Thats easy, they should be painted body color. The black wind deflectors mount with 7/16 inch threaded bolts on top. The lower bar is fastened to the deflector with #8 buttonhead screws with washers and nuts and are painted black also. I assembled the whole thing and loosely mounted all until I was ready to mount the grill teeth and outer trim pieces.
Good Luck.
Digger
Hi Mark,
I'll try to give some information on this: I looked in the Body Service Parts List, and I don't see any connectors listed for the top corner of the air deflectors although it does show the lower horizontal (zinc hex head screw, 1/4" shaft diameter and 3/4" long) and vertical (zinc panhead screw, 3/16" shaft diameter, 1" long) dimensions. Anderson and Moment's restoration book says (page 147) they are "fastened through tabs at their top rear corners to holes in the subframe on each side near the S-brace, with hex bolts,nuts and washers."
The Body Service Parts List has a picture of the screws used to attach the splash panels, but no dimensions. Again, Anderson and Moment's restoration book says (page 142) that they are attached with "large Phillips truss-head sheet-metal screws. Panels and fasteners were body colored."
Cheers, Gary Patterson
B Air Deflector Assembly Austin Healey 2
Crankshaft TR2/3/3A Air deflector order of assembly Triumph 5
J Moss OEM AIR DEFLECTOR ASSEMBLY Does it do anything? Austin Healey 9
55modified need help with custom air deflector for BN1 Austin Healey 12
R Air Intake Deflector - Radiator Austin Healey 8
K Radiator air deflector Austin Healey 6
H Rad intake air deflector plates Austin Healey 6
af3683 TR2/3/3A Radiator Air Deflector / Shroud Triumph 31
I TR6 radiator air deflector recommendations Triumph 10
Tinkerman TR2/3/3A Air Deflector Installation Help Needed Triumph 19
Stinger TR4/4A TR4A Air Deflector Duct Triumph 1
E Air Deflector Color Austin Healey 13
A TR6 Stromberg CD2 Air Cleaner Covers Triumph 3
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
E MGB Oiling foam air filter MG 3
E MGB SU carb air cleaners MG 10
RAC68 Cold Air Bilge Blower update Austin Healey 13
P TR6 New front shocks & air in clutch Triumph 15
N Air filters Austin Healey 5
M Cooper's Air Filter on H1 Carbs Spridgets 5
TomMull Scroll Air Compressor Restoration & Tools 13
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR6 Tr6 fresh air vent replacements Triumph 1
