TR2/3/3A TR2 Sway bar questions/info request
TimK1955tr2
Hi, would anyone have experience with installing a front sway bar on a TR2 or early TR3?
I noticed TRF has a sway bar kit for a TR3A/B but I am wondering what is different for the earlier cars?
I can't imagine the drum brakes interfere?
Thanks in advance for any thoughts or info...
TR3driver
Great Pumpkin - R.I.P
The difference is that the aftermarket bars mount into the bumper supports, which are completely different on the "smallmouth" cars. Even the factory TR4 bar mounts will interfere with the early bumper supports.
One possible solution, which I plan to try (when I find some bumper supports), is to weld in a flat plate between the two bars on each side, to provide a mount for the sway bar pivots.
T
TimK1955tr2
Thanks for the reply Randall!
So a TR3A/B sway bar should "fit" regarding the width of the sway bar and how it connects to the suspension, the earlier cars just need a mounting bracket fabricated either using the bumper brackets or specific bracket mounted off the frame.
I do have a TIG welder to fabricate the brackets, I thought that was going to be the issue. I just wanted a second opinion before purchasing a sway bar and trying to make it work, in case I was overlooking another problem.
I will report back if I do end up taking on the project...
TR3driver
Yes, should work fine. I actually had the ADDCO bar from my TR3A mounted to my current TR3, when it was wearing the 3A apron, bumper and brackets. It fit just fine.
Here's a shot of the bar installed on TS13571L, using the bumper brackets from my wrecked 3A.
WiscTR
Memo to self re: pic in previous post -- did British Leyland, Rootes Group, etc., ever have an interest in a kitty litter production facility :smile:
TR3driver
Yup, it do "mark its spot". Someday, I plan to pull the (original) engine for a rebuild, but right now I'm having too much fun driving the car. And the leaks have slowed down somewhat since that photo was taken (it now has a new pan gasket and a new steering box seal; in addition to the proper small mouth apron and no sway bar).
There is still kitty litter on the driveway, though :smile:
Just curious, is there anyone else on this forum (besides Don Elliott) that routinely puts 10k/year on a TR3?
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
R TR2/3/3A TR2 Scam Triumph 13
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
