Source for correct washer for overdrive drain plug
bighealeysource
Bronze
Hey all,
The replacement gasket available from Moss and others for the large overdrive drain plug - brass one - does not fit well. Since it has to get past the threads of the plug, has to be a bit oversized so as a result slides around once in place past the threads and in my opinion, makes it prone to leaking. Anyone know of a better one available out there or has anyone tried a large rubber O ring or something that might snug up nicely. I've tried hylomar gasket maker resistant to gas and oil but that didn't work.
Thanks
Mike
PHulst
Bronze
I like the o-ring idea. Just wondering if that might allow for a better seal, and stay tight to the plug. There is enough room between the end of the threads and the head of the plug that it appears feasible.
blueskies
How about using the replacement gasket along with a couple of layers of teflon tape on the threads? An O ring may be worth a try, but I haven't had great luck using O rings on leaky oil pan plugs.
Deleted member 19315
bighealeysource
bighealeysource
Bronze
Hey all,
Thanks for the feedback. Haasad the dowty washer looks like exactly what is needed if I can get one that will fit over the threads of the brass plug if the rubber gives enough when pushed down on the plug. Going to see if I can find a source over here.
Thanks
Mike
A hydraulic hose or fitting supplier maybe for heavy plant would be where I would look.
Hope it helps
bighealeysource Anyone know of a source for correct size "M" for 100M models ? Austin Healey 0
M Phillips Head Screw Source with Correct Markings Austin Healey 8
Randy Forbes Help! Need source for "correct " trunk hinges... Austin Healey 5
Nelson Source for washers Spridgets 4
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
D General TR Front carpet source? Triumph 1
