TR2/3/3A Source for quality parts
Jayplum
I’m a little gun shy on ordering critical parts after the piston failure addressed in another thread.
I’m losing confidence in the big parts houses.
I have gotten good parts from each but this time is the final straw.
Where can I trust for quality pistons and sleeves?
I may be a conspiracy theorist but i don't believe in coincidences. I have heard of other failure and now have suffered one myself.
I ordered the Piston and Sleeve set and now that I need a replacement, EVERY jobber is BACKORDERED both here and in the UK. I does seem to be a RECALL of defective parts. If it walks like a duck and sounds like a duck, it is probably....
  • 1C2CFDFA-0982-4DEE-922D-A33AD9D393E2.heic
lram59
Member
How about hunting up a good set of originals? Still plenty of them out there I would think. A lightly used set can be deglazed, add a set of new rings and be good to go. If the pistons are a little worn they could always be knurled like they did years ago. It was only good for 10 or 12k but that could be 10 or 12 years in this market. I have a set of 83mm pistons and liners myself around here somewhere.
Larry
CJD
I'm probably the worst to ask. I was so paranoid that I ordered 3 sets for my TR2...studied them for 2 weeks and finally picked the one I liked the best. The problem I saw was none of the suppliers even know who the manufacturers are. I had to get them in hand to figure it out. There is a set of 89mm's in stock on ebay. Occasionally I have even seen some NOS real Triumphs show up there, but not at the moment.
Hamish Racing
If you are buying from the Uk anyway. There is REVINGTON TR yes very costly but very good parts.
After a lot of homework to find an engine builder I have just had my engine done by TR Enterprises and they do parts. Mention me and they will know the connection here. I don’t benefit but they’ll know it’s not some random order. Worth an email to discus needs and quality concerns, its a specialist garage workshop primarily so they’ll supply what they use.
Unfortunately there can be a cost difference to the high volume sellers but you should get it right first time.
Jayplum
Jayplum
Yeah, I saw those 89s on eBay. Those are really race set up. Yo properly us them IMO I would need a new cam, lifters, rockers and head.THAT would be a lot of fun. speaking of eBay, have you seen the white 3 for $42,900. It is a beauty. There is another one on BaT red one that truly looks to be concours level. Oh well, back my little one; I believe I better stick to 83-85mm; I’m told with an early model head it’s best. Thanks for the note and if you spot anything, let me know. I don’t mind paying hood monies for good stuff, NOS or good LKQ OE set.
Jayplum
Jayplum
Quite impressive shops, all three. I sent a note to TR Enterprise first. Thanks
CJD
I'm afraid I have had no better luck with Revington. They have stuck me with about $1000 of useless parts during my restoration. Granted, they were not engine parts, but I still would not trust them any further than the other suppliers, and returning parts to them is much more difficult.
Jayplum
Jayplum
Thanks once bitten shame on them.
twice bitten shame on us.
Joel Lester
I went with the 89mm piston liner set from Rimmer bros. They were by far the cheapest (for the 89mm). Probably the biggest reason to go with the 89's in that they are forged pistons - all the other sizes seem to be cast pistons. The forged pistons are significantly stronger and a lot less likely to have that failure you were worried about in the first place. Anyhow... that my two cents worth...
Joel
Jayplum
Jayplum
Understand the 89s can be cut down due to the metal and the extra wall thickness.
Moss has accepted my return and has made it good. So, I will be staying with the 87s.
Did you change the head to fit the 89s. That along with bigger cam and header would really perk it up.
Joel Lester
Went with a "road" cam from Newman in the UK. It was by far the cheapest yet still offered the performance characteristics I was looking for in a street engine - low down power and improved torque. I'm in the process of doing the head and got a great tip from John and that is to use the 89mm head gasket as a template to see of much material I can remove just under the intake valves since the 89's are bigger. The things you learn from this forum (and John) seem to be never ending. Love that.
AUSMHLY Need source for a quality radiator cap Austin Healey 8
I TR6 Good quality part source for TR6 carbs? Triumph 3
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
D General TR Front carpet source? Triumph 1
Steve P. Best source for new tappets? Austin Healey 11
I General TR Source for glass mirrors Triumph 5
