Source for Small U Bolts on 1/4 Elliptic Springs-
Jim_Gruber
OK Team I tried to rush and remove the Small [ U Bolt on Bugsy's 1/4 Elliptic Springs. Not a part available via MOSS, MOSS- UK, AH Spares, McMaster Carr. McMaster Carr smallest I.D. is 2". 1/4 Elliptics are 1 3/4" wide. Anyone got a source for a replacement or what have you used in the past. .
The_architect
I used these 2 1/16 wide 3/8" heavy duty galvanized u-bolts I bought from Amazon: https://www.amazon.com/gp/product/B00YMTQLHQ?psc=1&redirect=true&ref_=oh_aui_detailpage_o06_s00
and made a strap from a piece of flat iron.
When you review the 1 3/4"wide u-bolts from Pacific Trailer, note that the because of the radius at the corners, the effective width is only about 1 1/2" even though the legs are 1 3/4" apart--does this make sense? You are going to have a gap at the end where the bolt crosses the strap. You don't want that, you want them to be tight. You actually need something a little wider.
I had to run a die down mine to get a little extra thread, because they were not threaded long enough, but they worked great. I had previously used 2 x 5/16 and found they were not heavy enough and were getting bent up. One of the original u-bolts I took off was actually broken at the bottom near the strap. Looked like it had been that way for many years.
Jim_Gruber
Jim_Gruber
Thanks for the update. I'm checking on u bolts from a place in Portland I asked for a quote for 17/8" wide that duplicates original in Grade 8. Should have a price. Better yet Rick Fisk thinks he has a set in his basement. Hopefully I can find OEM parts. Thanks.
ps thinking 2 1/16 could you use shouldered spacers of some sort to go over the legs to get the ID down to 1 3/4. A thought.
The_architect
You could Jim, but on mine once they were are torqued down were are not going to move. The radius at the top keeps them in place-on any of these where a piece of round stock is heated and bent, it is quite large. If Rick can find you OEM that would be wonderful. I should mention, on those that I bought the galvanizing was extremely thick and heavy--these were intended to be used on boat trailers.
Jim_Gruber
Jim_Gruber
Awaiting feedback from Rick, see my note on ahexp re. derusting process and flapper wheel. All springs cleaned up in 45 minutes, mess of shop, but a nasty job done.
Just saw a post on AHEXP from Rick ... looks like you struck gold ...er... rust. :smile:
Jim_Gruber
Jim_Gruber
Please see the PM I sent to you. Yes those are like finding gold. All I need is the small U Bolt. Hate to break up a set of usable springs if I can avoid it.
twas_brillig
Jim_Gruber
Jim_Gruber
Although that looks like it, that one is the large u bolt that attaches the spring to the floor pan bracket. At least that's what it appears to me. Thanks anyway. Found one however. So hunt is over. Thanks Team��
Jim_Gruber
Jim_Gruber
Two Thumbs Up and Thanks to Trevor for sending me two u bolts that I needed. Thanks to Rick Fisk as well for offering up a set of 1/4 elliptical. Rick save Thise for someone in desperate need. I'm covered. Thanks again to all on this Team for your help and support
drooartz
Excellent! Spridget people are good people.
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
D General TR Front carpet source? Triumph 1
Steve P. Best source for new tappets? Austin Healey 11
I General TR Source for glass mirrors Triumph 5
Patrick67BJ8 "Cover" for Top. Source wanted Austin Healey 6
O TVR 2500m weatherstrip source needed TVR 2
