General TR Emergency hot wire - because you never know whats next
'72 TR6 Last week the car stopped on the road. Dead, total blackout, no lights, starter, nothing. The problem was the power to the ignition switch from the ammeter became discontinuous(the exact failure is yet unknown). The short term fix was to run a jumper from an unused tab on the overdrive junction through the firewall alongside the main harness and connect to the ignition switch. It seems that with such a complete failure mode that can occur without any warning, having an emergency "hot wire" in the tool box/road kit/glove box could save the day should it happen to you while on the road. About 2 1/2 ft long, with a 3/8 in slide-on connector on one end and a 1/4 in connector on the other end is all it takes. I used 12 ga wire to handle the load. Maybe I should go into production and market these! Sort of like the emergency bonnet release device... Happy driving!
TFB
I made up one with an inline fuse while troubleshooting my ws wiper motor.Now its in the trunk tool bag,with spare fuses.
Tom
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
R TR2/3/3A Emergency Brake Adjustment Triumph 29
I Wanted emergency brake rods from later Spridget Spridgets Classified 0
maxwedge5281 adjustment of emergency brake Austin Healey 4
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
T TR2/3/3A Emergency Brake Handle Triumph 7
W Emergency rotor fix Austin Healey 2
bigjones Installing a spare distributor in an emergency Spridgets 52
G TR4/4A Emergency brake dust covers Triumph 4
RJS Emergency hood/bonnet release Triumph 22
B MGB Dumb emergency brake questions...help requested! MG 5
J TR2/3/3A Dissassemble TR 3A emergency brake handle. Triumph 4
G Emergency...Sorry MG 19
Trevor Jessie Emergency Stop Spridgets 8
J Emergency brake lever needed Spridgets 2
jvandyke emergency help needed in Linden, NJ Spridgets 21
Morris Emergency advice needed Spridgets 13
H Triumph Emergency Kit Triumph 18
H Spring for emergency brake MG 0
lreyburn Road Trip Emergency Kit Austin Healey 18
D Spitfire Spitfire emergency brake assembly - need photos Triumph 3
newmexTR3 emergency advice needed! Blown pushrod Triumph 17
S Emergency Brake cable FORUM Navigation Questions 0
S Emergency brake stuck MG 12
S Emergency Brake cable MG 6
M Need Some Advice on a BE Emergency Brake Spridgets 13
JPSmit emergency brake light switch Spridgets 6
JPSmit Quick question #2 Emergency Brake Spridgets 1
A Emergency Brake Handle Correct Reassembly Order ? Austin Healey 2
RickB FIXED - Distributor removal 'emergency' [not] MG 39
D emergency brake cable Spridgets 2
L Emergency Question: Time sensitive Spridgets 4
healeyboz emergency brakes Spridgets 6
Woodie Urgent help...emergency flasher wiring Spridgets 7
T TR6 tr6 topseal emergency! Triumph 8
regularman The spridget long trip emergency tool kit Spridgets 21
ScottTR6 Emergency bonnet release Triumph 12
Woodie emergency flasher switch Spridgets 7
M Spitfire Removing the emergency brake grip;1979 Spitfire Triumph 0
kodanja Emergency Brake Knob? Triumph 8
MadRiver Emergency Bonnet Release Install Q's. Triumph 10
I TR6 Emergency parts for TR6 road trip Triumph 6
TR4nut Poor Man's Emergency Bonnet Release - It works! Triumph 5
T Where do I attach a tow line for emergency tow ? Triumph 6
Brosky New "Emergency" Hood Release Kit arrived today Triumph 3
Sherlock 1957 Wolseley [in CA] - emergency rescue Other British Cars 5
