Wire Wheel Fit
Riquet1963
Hello,
I have one question about the wheels.
Today during my Sunday afternoon trip in my BJ7, I had a flat tire. I tried without success to put on the spare wheel. In fact, it was impossible to push the wheel in the grooves! I checked the wheels and my constat [? -Mod.] is: The four wheels on the vehicle have 60 spokes, and the spare wheel has 48 spokes.
Question: Are the grooves different between the 60-spoke and 48-spoke wire wheels?
Many thanks for your advice.
BR
Eric G
pan
G'day Eric,
There shouldn't be any such difference between a 48 spoke wheel and a 60 spoke. Sometimes if the wheel or the hub extension is new there will be a snug fit, but will still fit. You haven't got a wheel from another car have you? Don't laugh, it happened to me once with a Jaguar. For months I carried around a Holden wheel as a spare, but when I had to use it it didn't fit. Then I noticed it was a 14" wheel instead of 15". Seems that before I bought the Jaguar the wheels had got mixed up when having punctures repaired. They were both the same colour and had the same brand of tyre mounted.
R
Riquet1963
Many thanks for your replies
Last question for you it's possible to have the spoked wheels with different groove for other brand like Jaguar, mg, ...?
BR
Eric G
pan
G'day Eric,
Jaguar cars with wire spoked wheels have larger hubs than the Austin-Healey.
The Jaguar that I had was fitted with steel disc wheels, that is how the spare was accidentally swapped for the Holden wheel. Holden was an Australian car built by General Motors. Now sadly, no longer made.
billspohn
There are only the two sizes of spline, small and large. Small fits AH, TR, MG, Aston, Sunbeam etc. and large fit Jaguar. I even owned an early Lamborghini that has the same spline as an MG (see below). If the wheel won't go one the splines and they are the right diameter, then it is likely a case of wear on one or both spline and wheel.
Healey Nut
Spline drive wheels need to be regularly removed and the splines cleaned and lubricated accordingly .
My cars had them removed at least 2 or 3 times a season for wheel cleaning and spline checks etc .
Anti seize compound is your best friend .
At one time--for 30 years or so--I would have agreed. But I re-thunk the common wisdom and came to a different conclusion:
-- anti-seize is great for what it's formulated for; i.e. creating a corrosion barrier between metal parts, usually iron or steel, that don't generally move about. For parts that get hot; i.e. spark plugs, an 'exotic' metal anti-seize like nickel-based ($$$) is best, yet when you remove the plugs the oily part is gone and only the metal filler remains
-- anti-seize is not formulated to prevent wear--presumably, why it's not called 'anti-wear'--and the splines on both the wheel hubs and chassis hubs DO move against each other if only a minuscule amount (esp. when braking). This is why even hubs slathered with anti-seize will eventually wear, as evidenced by the splines becoming knife-edge sharp and at risk for being spun
-- anti-seize will prevent the hubs from 'welding' together, but I submit it's the wrong thing to use on WW hubs for wear prevention
So, for a couple decades or so I've used thick grease on the splines. Until a couple years ago, I would drive my BJ8 for 5-8K miles a year, often through adverse weather, i.e. rain and snow, and a good coating of grease always stayed put*. Well-greased parts generally don't rust together, and grease provides better lubrication. I use wheel bearing grease; Redline synthetic is the best I've found--I use it in my Healey wheel bearings--but Sta-lube High-Temp Disk Brake grease or comparable is good enough for the hubs.
* But not TOO thick, or a lot will end up on the splines and outside of the hubs. I use use RTV on the inside to seal the hub bases.
billspohn
Yeah, I also use a light covering of grease to exclude water - it stays in place better than anti seize does.
Down to only one wire wheel car - the other two are peg drive knock off, so no splines.
twas_brillig
Have a look-see at both the hub and the interior of the wheel. There might be a bit of mechanical damage to the edges of the spare tire splines that prevent them from slipping into place, or a hefty build of up the ubiquitous crud. Doug
Todd78d Wire wheel cleaner Spridgets 1
K 1068 mkIII wire wheel rub Spridgets 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
W TR2/3/3A Wire Wheel Conversion Triumph 5
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
P Wire Wheel Splines Austin Healey 10
RJS General TR Wire Wheel Spline Question Triumph 3
B TR4/4A Wire wheel question Triumph 10
P TR5/TR250 wire wheel question Triumph 3
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Leatherman TR2/3/3A Wire wheel conversion question Triumph 19
Joe Schlosser Wire wheel Parts Free to good home Spridgets 0
M Chrome wire wheel questions Spridgets 5
S Locknut - rear wire wheel - torque spec? Austin Healey 15
jfarris TR2/3/3A Wire Wheel Grommets Triumph 5
Raymond MGB Wire Wheel Tire Mounting MG 0
Raymond MGB Wire Wheel Cotter Pin MG 5
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
B General Tech Wire wheel sealing bands? MG 4
J For Sale Wire wheel set Triumph Classifieds 2
maxwedge5281 wire wheel conversion to road wheels Austin Healey 21
CJD TR2/3/3A Wire Wheel Locating Collar 108942 Triumph 15
M TR2/3/3A Wire Wheel Splines Triumph 3
Zitch Wanted WTB - One good wire wheel for Spare [15x4.5] Triumph Classifieds 1
S MGA wire wheel space saver spare MG 1
N Wire wheel hub removal & suspension tear down Spridgets 3
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
PAUL161 General MG Wire wheel balancing service MG 2
S General TR Wire Wheel New Tire Installation Question Triumph 11
GTP1960 TR2/3/3A Hub extension torques? [for wire wheel] Triumph 4
S TR2/3/3A Wire wheel balancing Triumph 16
M wire wheel spokes "tuning" Austin Healey 8
S TR2/3/3A 155/15 Vredestein Sprint Classic on a 4.5" Wire Wheel as TR3B Spare? Triumph 6
S TR2/3/3A Lug nuts for wire wheel adaptors Triumph 3
J General TR Wire wheel sale pricing Triumph 18
J How to repair a tubeless wire wheel leaker ? Austin Healey 10
K Original "old" 1960'es Dunlop wire wheel paint code Austin Healey 7
K Original 1960'es Dunlop wire wheel paint code Jaguar 7
K 1960'es Dunlop wire wheel paint colour code Restoration & Tools 0
K General Tech 1960'es Dunlop wire wheel pint colour code Triumph 13
5 Bugeye wire wheel dust caps Spridgets 4
mgbmedic Wire Wheel Conversion - What am I Missing? Triumph 11
P New England Wire Wheel Triumph 2
D new member with wire wheel questions Jaguar 6
D new member with wire wheel questions Austin Healey 7
D neww member with wire wheel questions MG 11
D new member with spoke wire wheel questions Triumph 12
