1933 Standard Little Nine Carburetor
tedwone
Does anyone out there have a carburetor for a 33 Standard Little Nine? The one on my engine is broken in several places and totally unusable. I rebuilt the engine several years ago and have not been able to find a carburetor to see if my rebuild was successful.
Roger
Bronze
What make and type (sidedraft, downdraft) of carb does it have? I dont know prewar Standards, but imagine that there must be another make with compatible carb.
PAUL161
Did you know,
The story of Standard starts with one Sir John Wolfe Barry, who designed London’s famous Tower Bridge. After his young assistant, Reginald Waiter Maudsley, was left in financial straits by his father's death, Sir John Barry provided a cheque for £3000 to enable him to leave civil engineering and establish himself in the nascent British motor industry. Maudslay formed the Standard Motor Company in Coventry on 2 March 1903, with a total capital of £5000, a small factory in Much Park Street and offices in Earl Street.
Chairman of the tiny company was Maudslay, while his chief engineer was Alex Craig. The car that they produced incorporated only those principles which had been tried, tested, and found to be reliable ( many of them seemed to have already been tried in Craig's designs for Lea Francis and Singer). Because the car was built on proven principles, Maudslay named it the Standard. The first Standard was a solidly built Motor Victoria with a very over-square engine of 5 in bore x 3 in stroke (available in both single and twin-cylinder forms) mounted under the driver's seat. The two-cylinder version cost £367 10S in the UK. Total 1903 output was six cars; the workforce consisted of six men, who the following year increased production to the staggering total of nine cars.
Also, contributing to the war effort,
When World War 2 broke out the Canley factory once again turned to the manufacture of aircraft: this time over a thousand De Havilland Mosquitoes were built as well as Airspeed Oxford trainers. Component manufacture included items as large as complete Bristol Beaufighter fuselages and as small as bomb releases; 20,000 Bristol Hercules aero-engines were built, and 417,000 cylinders for Bristol Mercury and Pegasus engines. Vehicles were produced, too: some 10,000 light utility vans were built for military use, based on the pre-war Flying Standard 14 chassis, as were 2800 examples of the curious Beaverette. This was a light armoured car on the 14 hp chassis, intended mainly for use by groups such as the Home Guard in the event of invasion.
T
tedwone
It is a Solex downdraft, but I haven't looked at it for years. I have thought about checking out early VW carbs that I can adapt.
T
tedwone
Yes, there were many other models of the Standard of that period, most of which were larger and had more horsepower. This car has a one liter engine and has a rated top speed of 55mph. I'm not sure if I will ever see it on the road in my life time, but I hope I can squeeze more than 55mph if I am able to get it on the road again.
Deleted member 8987
Bore and stud spacing.
I won't let you have any of my Jag Solexes (downdraughts), but I do have a couple of MB "Pontoon" Solexes.
T
tedwone
I have two questions: Can you send me a photo so I can confirm that this is the same as the one I have and how much in $US would you want if it is the correct one? Thank you so much for responding to my query.
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
bgbassplyr 1933 J 2 for sale MG 3
YankeeTR Swedish Gran Prix 1933... Triumph 7
pj777 Vintage 1933 Sunbeam & Fuel Sunbeam (Rootes) 5
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage MG Classifieds 0
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage Austin Healey Classifieds 0
S Wanted 1949 standard vanguard Other British Classifieds 0
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
HalLucy Standard Vanguard Sportsman engine and the TR3 Other British Cars 7
M TR2/3/3A Standard Engine Trust Washer Thickness Triumph 18
S General Tech Standard for the Girling Bubble Flare Triumph 15
T Wanted Workshop manual for Triumph 10 [Standard 10] Triumph Classifieds 4
Mickey Richaud General TR Standard 10 Pickup! Triumph 3
NutmegCT 1951 Standard Vanguard Other British Cars 3
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
Tim Tucker TR2/3/3A TR2-4 86mm standard rings Triumph 10
RickB standard size lug studs for 78 Midget? Spridgets 3
C Triumph Standard Flying 8 Triumph 5
M Thak you and Metric or standard.... ? Austin Healey 5
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
rlich8 Standard-Triumph Engine Package Diagram Triumph 4
K Early 50's Standard Triumph 1/2 Ton? Triumph 8
wangdango Vandervell bearings for 100M, standard, main Austin Healey 3
bighealeysource Pertronix coil verus standard Lucas coil Austin Healey 3
QuickSilver Technical: Converting From Wire Wheel To Standard MG 6
kurts100 Bugeye Lever Shocks/Standard or Heavy Duty Rebuild Spridgets 14
hilsideser Standard 10 in S.C. on Craig's list for $300 Triumph 20
K TR2/3/3A Standard Continental Touring Kit for TR3 on EbayUK Triumph 0
TR4nut Standard Triumph Gray Colors for Russ.. Triumph 15
K 1950 Standard Vanguard Other British Cars 2
T Neat project - Triumph Standard 10 Triumph 11
Ohiobugeye Metric or US Standard Threads? Spridgets 26
Wirewheels Did the BJ7 come with OD standard? Austin Healey 11
germanmichel Standard clearance mainshaft of the transmission ? Austin Healey 3
W TR10 / Standard Axle for Lotus Triumph 10
pakiwi 1275 Cam Specs - Standard Spridgets 1
PeterK standard-triumph hardware catalog Triumph 7
MadRiver TR6 Standard TR6 Tires? Triumph 2
ncbugeye Tyres for standard Bugeye rims Spridgets 1
G Standard Vanguard Paint Code Other British Cars 4
Alan_Myers If I had room, time, $! FS: '47 Standard Flying 14 Triumph 2
Sherlock Standard Herald [India] Other British Cars 5
A MGB How much Torque can a standard MGB gearbox handle? MG 5
bobh A Radical Idea? Or An Old Standard? Triumph 11
gsalt57tr3 1953 Standard Vanguard Phase II Other British Cars 0
gsalt57tr3 Standard Vanguard Triumph 2
gsalt57tr3 Standard Vangard in St. Louis MO Triumph 2
Webb Sledge David Vizard: Tuning Standard Triumphs Triumph 2
Sherlock History question - Standard-Triumph of Belgium Triumph 3
R air shocks vs.standard type? Triumph 3
