GT6 C.D.S.E.V carburetor question
svtmikey
Hi there,
I have 69 GT6 + with C.D.S.E.V. carbs (I think) becuase they have the non-adjustable Float chamber pug on the bottom of the float chamber, not the adjusting orifice that is on the earlier ones...please correct me if i am wrong.
My problem is that I seem to be running lean, the car that is ,not me as I am not lean at all these days, and I can't seem to find a way to get the mixture richer.
Anyway, I believe that these carbs "should" have adjustable metering needles, that the appropriate tool fits in (from the top of the dash pot) that allows you to adjust the mixture by turning clockwise or counter clockwise.
My problem is that they don't have that.....
Has someone along the way, put in the wrong needles? Is that possible? Am I way out of line?
Any comments, or advice would be appreciated.
Thanks so much!
poolboy
The air valves in which the mixture needles reside is different for carbs with adjustable needles.
The air valves for adjustable needles have the 2 notches for the adjustment tool
On the left is the adjustment tool; on the right, the air valve for adjustable needles.
In this picture you'll see the adjuster in position in the air valve.
If you have the air valve with the 2 notches for the tool, you have the air valve for adjustable needles.
Here are the components of the adjustable needle.
The needle adjuster has a hex slot for the allen wrench component of the mixture adjustment tool... the adjustment range is less than 3 revolutions from fully rich (clockwise) to lean (counterclockwise).
Once you reach 2 1/2 CCW from fully CW, it's dangerously close to the separation of the adjuster to the needle carrier.
Do you have notches in the carbs' air valves ?
svtmikey
svtmikey
Poolboy, thanks for the response.
My air valves don't have the slots in them.....but they also don't have the adjustable float chamber plug on the bottom.
I guess it's possible that these were modified somehow, or is there a version of carb that doesn't have adjustable float chamber plugs and needle adjustment???
If so where might I adjust the mixture???
Thanks again
svtmikey
svtmikey
Thanks TR3driver,
Man, after reading the conversion article........I think I'll look for some pistons that are adjustable.......got any for sale????......LOL
Thanks
poolboy
I've managed to get my hands on a few air valves for adjustable needles from time to time for people wanting the conversion while I have their carbs for rebuilding, so it's possible you might luck up too..
Not too long ago I tried to convince Joe Curto to turn loose of a couple. I can't blame him for not, but in the conversation he mentioned he might make up a batch from the non-adjustable versions.
You might give him a call.
https://joecurto.com/contact
He might have the adjustable jet conversion like Goodparts.
https://www.goodparts.com/shop/index.php?productID=422
veale001 TR6 TR6 Carburetor Question........................... Triumph 5
d_valentino 100M Carburetor Question Austin Healey 4
G Carburetor Gasket Question Spridgets 21
Kurtis HS-2 Carburetor Setup Question Spridgets 5
S Carburetor Question Austin Healey 11
bluemiata90 TR2/3/3A tr3 carburetor rebuild question Triumph 9
J Carburetor Banjo Seals Austin Healey 11
zoohow TR6 Carburetor Conversion kit Triumph 2
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
P Zenith Carburetor Triumph 2
K Carburetor options for a 66 Austin 1100 ? British Motor Corp 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
A Spitfire Weber Carburetor Triumph 0
B gas leak underneath the carburetor Restoration & Tools 2
A TR6 Carburetor help Triumph 5
G TR6 Hacked carburetor? Triumph 6
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
AUSMHLY SU Carburetor Synchronizing Kit on eBay Austin Healey 16
C TR6 Carburetor Throttle Linkage Triumph 10
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
FlyingCat Spitfire No Gas to Carburetor Triumph 18
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
F TR6 Carburetor issues at low rpms webers Triumph 23
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
D TR2/3/3A '59 TR3A SU carburetor Triumph 4
AUSMHLY Front carburetor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
G Gasket sequence manifold to carburetor Austin Healey 4
ckeithjordan TR2/3/3A Carburetor Rebuild Triumph 26
F General MG Help needed with su dual carburetor identification MG 4
KVH TR4/4A Carburetor float bowls Triumph 8
M BN1 carburetor fuel line Austin Healey 9
fpstude TR2/3/3A TR3 Carburetor Adjustment Triumph 6
D S.U. HD8 Carburetor Drawing Austin Healey 6
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
Lutz Kramer Carburetor gaskets Austin Healey 8
B BT7 carburetor - choke - fuel questions Austin Healey 5
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Keith_M carburetor woes Spridgets 17
C HD6 Carburetor Spacer Blocks Austin Healey 4
C Carburetor Removal on a BT7 Austin Healey 7
C Carbon Deposits in Carburetor Austin Healey 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
D Wedge TR7 Carburetor losing dashpot oil Triumph 8
