Carburetor Banjo Seals
joe948
I am having a heck of a time with the banjo seal on a 65 BJ8. Covers were off and now can't get new fiber gaskets to seal, recessed area on outside.
Cleaned up the fittings and hate to go too much more to tighten. Do they need time to form or set up?
Seems like they go a little more after sitting. Any tips? Use sealer? Thanks in advance.
Dandare
The original fibre washers were intended to be soaked in kerosene for a time before use. I'm not sure that the new ones are the same material but would be worth a try.
Danny
Agree on soaking; not having kerosene handy I use WD40 (gasoline would work too). There are RTV/silicone sealants that claim 'fuel resistant;' a very thin coat might help/wouldn't hurt (I've used it elsewhere). I'm not sure what 'recessed on outside' means; newer few pumps, which used to use the same fiber washers on flat sealing surfaces now come with O-rings that sit in a recessed bevel on the inside of the sealing surfaces. Note OEM/earlier fiber washers were brownish in color, modern ones are usually black and (possibly) thicker; I'm not sure they work as well as the original. Both types deform after installation; you usually have to tighten the banjos up after they've been in use for a while.
SNClocks
Member
Honestly, the fiber washers are a joke - presoaked in kero or mineral oil or whatever. Many years ago (think 40) when I mounted triple SU's on our XKE, I tapered the sealing face of the banjos with a 45 degree tapered grinding stone in a drill press. I then installed them with "O" rings that were compatible with gasoline - take your pick - > O-Ring Compatibility Chemical Resistance Chart <. They don't leak. And they last like forever.
Michael Oritt
Maybe I've been lucky but I have never had a problem with any of the fiber seals beyond their occasionally needing a little more tightening. I do, however, like Stephen's idea of replacing them with O-rings and wonder which one he used for what I must assume is "gasahol". The chart seems to suggest nitrile.
SNClocks
Member
Funny - nitrile has been my choice for gasket materials for a very long time. When reformulated fuels were destroying the kits for SU's I made up new diaphrams for SU's - and they are still there now.
J
joe948
The seals tighten up more after sitting over night, seems to be finally slowing down. The new seals were a red brownish color from a small gasket set. By recessed I meant the side of the banjo fitting the bolt goes in. This all began with starting hard, cleaned up the needle valves but still getting gas out the overflow. Still a needle problem? Do I need new needles? Car will stumble but not catch. Always been fine before.
Thanks for the response.
John Turney
If you are getting fuel out of the overflow, it's the float level or the float valves that are leaking. Fuel level normally doesn't come to where the banjo bolt washers are when not moving. When the car is moving, fuel in the bowls will slosh around.
Goldie
I had a similar problem when I replaced the fuel lines to the carbs in my BJ8. Turned out I needed to flip the rear carb banjo over 180 degrees. I had the recessed side toward the carb which seemed logical.....NOT. It kept leaking after soaking, etc. until I flipped it over. The forward carb has a different banjo fitting so it did not leak.
BLU_HLY
Member
  • SEAL WASHER ASSY ON BANJO.pdf
  • Hly banjo seal washers...pdf
SNClocks
Member
I don't think I have ever seen a set of banjo fitting on the fuel lines going to carbs that did not show evidence of seeping. Hence my use of nitrile O rings. Not that hard to taper the seats on the banjo's and a permanent solution.
Just my 2 cents, which is now worth perhaps a Mexican peso, if that.
zoohow TR6 Carburetor Conversion kit Triumph 2
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
P Zenith Carburetor Triumph 2
K Carburetor options for a 66 Austin 1100 ? British Motor Corp 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
A Spitfire Weber Carburetor Triumph 0
B gas leak underneath the carburetor Restoration & Tools 2
A TR6 Carburetor help Triumph 5
G TR6 Hacked carburetor? Triumph 6
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
AUSMHLY SU Carburetor Synchronizing Kit on eBay Austin Healey 16
C TR6 Carburetor Throttle Linkage Triumph 10
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
FlyingCat Spitfire No Gas to Carburetor Triumph 18
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
F TR6 Carburetor issues at low rpms webers Triumph 23
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
D TR2/3/3A '59 TR3A SU carburetor Triumph 4
AUSMHLY Front carburetor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
G Gasket sequence manifold to carburetor Austin Healey 4
ckeithjordan TR2/3/3A Carburetor Rebuild Triumph 26
F General MG Help needed with su dual carburetor identification MG 4
KVH TR4/4A Carburetor float bowls Triumph 8
M BN1 carburetor fuel line Austin Healey 9
fpstude TR2/3/3A TR3 Carburetor Adjustment Triumph 6
D S.U. HD8 Carburetor Drawing Austin Healey 6
svtmikey GT6 C.D.S.E.V carburetor question Triumph 5
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
Lutz Kramer Carburetor gaskets Austin Healey 8
B BT7 carburetor - choke - fuel questions Austin Healey 5
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Keith_M carburetor woes Spridgets 17
C HD6 Carburetor Spacer Blocks Austin Healey 4
C Carburetor Removal on a BT7 Austin Healey 7
C Carbon Deposits in Carburetor Austin Healey 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
D Wedge TR7 Carburetor losing dashpot oil Triumph 8
bigbadbluetr6 TR6 TR-6 Carburetor rebuild kit Triumph 6
DornTRoriginal TR2/3/3A Carburetor Link Rod Ass'y Installation and Fuel Line Installation Triumph 1
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
SMGoose Carburetor piston not falling freely Triumph 7
D Carburetor Backfire on acceleration at low speed Austin Healey 18
