Carburetor options for a 66 Austin 1100 ?
karls59tr
Bronze
Does anyone know if dual carbs were an option for the 1100? I had one back in the day and it had two SU's but the few remaining ones that I have seen only have a single SU?
BobHaskell
SU Carburetter Service Parts List (AKD 5036) from 1966 - Austin and Morris 1100s were all single carb:
  • AUD 13 (HS2) Austin 1100 and 1100 Mark II (all versions except Automatic)
  • AUD 185 (HS4) Austin 1100 Automatic
  • AUD 251 (HS4) Austin 1100 and 1100 Mark II Automatic (after engine 10AG/A/H158)
The MG 1100s were twin carb:
  • AUD 2 (HS2) MG 1100
  • AUD 69 (HS2) MG 1100 (after engine G-GS1-627)
The Riley Kestrel 1100s were twin carb (AUD 69).
K
karls59tr
Bronze
Well that's interesting. Maybe it was actually an MG 1100 that I owned and not an "Austin"1100 ? Was there much difference in the two models? Mine was a 1966 model. Another thing I noticed about the 1100 that I was looking at the other day is it had a small blinker light on the end of the turn signal lever. I don't recall that in my car. I'm guessing that was an Austin thing along with the single carb.
BobHaskell
I would think that a dual carb setup would be a bolt on modification to an Austin 1100. Our '64 Austin Mini has the same blinker light.
J Carburetor Banjo Seals Austin Healey 11
zoohow TR6 Carburetor Conversion kit Triumph 2
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
P Zenith Carburetor Triumph 2
KVH General Tech HS6 Carburetor Bushings Triumph 10
A Spitfire Weber Carburetor Triumph 0
B gas leak underneath the carburetor Restoration & Tools 2
A TR6 Carburetor help Triumph 5
G TR6 Hacked carburetor? Triumph 6
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
AUSMHLY SU Carburetor Synchronizing Kit on eBay Austin Healey 16
C TR6 Carburetor Throttle Linkage Triumph 10
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
FlyingCat Spitfire No Gas to Carburetor Triumph 18
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
F TR6 Carburetor issues at low rpms webers Triumph 23
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
D TR2/3/3A '59 TR3A SU carburetor Triumph 4
AUSMHLY Front carburetor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
G Gasket sequence manifold to carburetor Austin Healey 4
ckeithjordan TR2/3/3A Carburetor Rebuild Triumph 26
F General MG Help needed with su dual carburetor identification MG 4
KVH TR4/4A Carburetor float bowls Triumph 8
M BN1 carburetor fuel line Austin Healey 9
fpstude TR2/3/3A TR3 Carburetor Adjustment Triumph 6
D S.U. HD8 Carburetor Drawing Austin Healey 6
svtmikey GT6 C.D.S.E.V carburetor question Triumph 5
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
Lutz Kramer Carburetor gaskets Austin Healey 8
B BT7 carburetor - choke - fuel questions Austin Healey 5
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Keith_M carburetor woes Spridgets 17
C HD6 Carburetor Spacer Blocks Austin Healey 4
C Carburetor Removal on a BT7 Austin Healey 7
C Carbon Deposits in Carburetor Austin Healey 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
D Wedge TR7 Carburetor losing dashpot oil Triumph 8
bigbadbluetr6 TR6 TR-6 Carburetor rebuild kit Triumph 6
DornTRoriginal TR2/3/3A Carburetor Link Rod Ass'y Installation and Fuel Line Installation Triumph 1
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
SMGoose Carburetor piston not falling freely Triumph 7
D Carburetor Backfire on acceleration at low speed Austin Healey 18
