Gasket sequence manifold to carburetor
Gadwhite
Hi all. having trouble figuring out the sequence of installation of the gaskets between the intake manifold and the carburetors on my wifes BJ8. I have a metal faced gasket, a black fiber gasket, and a red fiber gasket. these are the gaskets that go between the manifold and the plastic block, the plastic block and the heatshield, and the heatshield and the carburetor. Have checked the shop manual( hayes and the big green one) no luck. please help
Here's how I do it:
1) metal faced gasket; metal side to manifold (that's where the heat is)
2) plastic (bakelite?) spacer
3) paper gasket (usually, they're black)
4) heat shield
5) paper gasket #2
6) carburettor
This is one place I don't use any 'gasket goop;' never needed it.
mgtf328
A timely question. I just bought a set of new "carb to heatsheild gaskets" from Ahead4healeys.co.uk here in the UK. They sent the paper gaskets. I called them and they don't have the metal faced gasket and didn't seem to know what I was talking about. There is a metal faced gasket already on the car as described above but fitted the wrong way round according to the post but it seems sensible to me that the metal should face the engine. I called Ahead4healey and looked up AHspares and neither of them sell the metal face gasket. Not sure where to get one over here so I am considering re-using the old one but am worried about leaks, don't want to have to take the carbs off again! Should I use the old gasket with some gasket sealant, any thoughts would be appreciated?
Thanks AJ
...I am considering re-using the old one but am worried about leaks, don't want to have to take the carbs off again! Should I use the old gasket with some gasket sealant, any thoughts would be appreciated?
Thanks AJ
As long as the gasket has no holes or tears I think it can be re-used (IIRC, I did just that on my recent rebuild). I've had trouble getting a good seal at the exhaust manifold to downpipes junction, esp. since the 'good' gaskets--with asbestos--haven't been available for years. I've been putting a smear of this stuff:
https://www.grainger.com/product/3D...0014!&ef_id=WblTWQAAAFTNxVbn:20180304160149:s
on both sides of the gasket, and double-nutting the studs--with anti-seize grease on the studs--with steel nuts and gotten good seals. Some of the downpipe gaskets were perforated silver metal--thin steel presumably--and some were copper-faced with a white material sandwiched between the metal and neither would give a good seal without the sealant and the double nutting (I tried new SS studs and new brass nuts to no avail). For the carb gaskets be sure to use only a thin smear else a gob could break loose and get into the engine (not much of an issue on the exhaust side).
I could swear I bought the metal-faced gaskets from Moss, but the newest catalog only shows what appears to be the paper gaskets.
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
B TR6 Gasket sealer Triumph 1
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Failed intake manifold gasket? Triumph 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
RJS TR4/4A Fuel Pump Gasket Triumph 8
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KVH General Tech Permatex Aviation Form a Gasket; Permatex Ultra Gray Triumph 12
P MGB Zenith water choke gasket needed MG 4
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
T TR2/3/3A tr3 head gasket Triumph 38
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
DrEntropy MGB Head gasket R&R goes on... MG 13
tahoe healey Cork Gasket Prep Austin Healey 17
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
LAW75 Timing Chain Cover Gasket Austin Healey 12
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
B Bonnet hinge gasket Spridgets 10
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
R BJ8 Cylinder Head Gasket Austin Healey 38
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
B TR4/4A Head gasket won't lay flat Triumph 13
T TR6 TR6 Carb Gasket Sealing Triumph 1
Michael Oritt Manifold Gasket Dressing/Sealant Recommendations Austin Healey 6
K Gearbox Throw-out pin and gasket question Austin Healey 8
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
D TR2/3/3A OD cover plate gasket sealer. Triumph 17
F Sump Gasket Question Austin Healey 15
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
F Heater valve/tap gasket- Install dry? Austin Healey 10
steveg Strange gasket pieces Austin Healey 5
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
Lin Oil sump gasket replacement Austin Healey 31
