Follow on questions from HD6 carburetor rebuild
fishyboy
Hi All,
Having rebuilt my HD6 carbs and fitted them back on my Healey a couple of things have come to light.
Firstly, my carb set up utlilises two black plastic spacers on each carb (one between the manifold and heat shield and one between the heat shield and carb body). Unfortunately I only noticed this after refitting the carbs while looking at some photos in one of my books. Should I take everything of a remove one of the spacers or just leave well alone (I assume a PO had put two spacers on for good reason).
Secondly, I notice that after I switch off the engine after a run I can see a few drips of fuel/air mixture dripping from the rear underside end of the inlet manifold onto the hot exhaust manifold, where they turn to steam. The drips stop after about 4-6 drips. Should I be worried? What does the underside of the manifold look like. With my fingers I can feel something like screws or bolts.
Any advice?
Thanks
Phil
Keoke
Yes there are copper drain tubes that attach to the intake manifold at the front and rear and direct the fuel away from the hot exhaust manifold.below.
Not sure what car you have, but if it has the 'log' style intake manifold there are drain holes on each end of the manifold. These holes should have a length of small ID copper pipe fitted to them to route unburned fuel past the manifold through the heat shield and to the ground. These need to be fitted--allowing petrol to drip on a hot manifold is a recipe for way too much excitement.
Patrick67BJ8
Here's pics of the drain lines from my BJ8. You can put a rubber grommet on the two small straps that hold them close to the side of the engine(bottom area), to get rid of the tinny type of noise that they make when vibrating in the strap holes.
CARSINC Follow My Spriget Blog As I Complete SpyderMite Spridgets 24
jlaird MGB Follow up to my bad post on prewar MGs MG 4
longbridgehealey Horn question follow up Austin Healey 12
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
P TR6 Follow-up to hard starting Triumph 4
drooartz The teardown begins, follow along at home! Spridgets 51
D TR6 Follow-up question Triumph 3
P Follow up to valve job Triumph 3
drooartz MGB Follow along as Drew tears down an MGB engine! MG 21
KVH TR4/4A TR4A OD Follow Up Triumph 10
tahoe healey Gunson colortune follow-up Austin Healey 17
nevets intermittant sputtering follow-up Austin Healey 13
eschneider TR2/3/3A follow up - TR3 broken pushrod &compression test Triumph 1
G follow up question on ZDDP Triumph 12
tahoe healey dizzy follow up Austin Healey 7
KVH TR4/4A Tires and Wheels on a TR4--A follow Up Triumph 9
G Follow-Up Horn Question Triumph 2
T Wedge Follow-on TR8 interior question - seats Triumph 4
N TR6 Follow up on lean TR6 carbs Triumph 1
J Failed State inspection-tie rod end..follow up Spridgets 4
C Follow up on Datsun 5 Speed Spridgets 11
RickB MGB-GT Follow up ?... Exhaust on the MGBGT all good MG 9
X Schumacher follow up. MG 3
martx-5 TR2/3/3A Follow-up on TR3 Master Cylinder Resevoir Triumph 2
jlaird Want to follow along Spridgets 11
B TR6 Follow-on question regarding new TR6 tires... Triumph 5
B Darn Things Follow Me Home. Spridgets 14
Trevor Jessie Repairing a dual gauge, follow up Spridgets 4
nevets OD follow-up Austin Healey 0
jlaird Follow on question, Differintal Spridgets 3
S atmospheric crankcase follow up Triumph 1
S Wedge The TR7 Fuel Gauge Follow-up Problem !?!? Triumph 12
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K General MG 1968 Midget Questions MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W General Tech 2500S starter motor and fuse box questions Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
P MGB 1980 MGB carb and oil questions MG 3
C My 2500M progress/questions thread TVR 5
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
B TR4/4A Dumb Bumper questions Triumph 4
B Two questions about Bugeye floor panel weld drilling Spridgets 15
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
R TR6 Questions on emission tank-to-canister pipe Triumph 0
AngliaGT MGB-GT Couple of Dumb Questions - '67 GT MG 11
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
D TR2/3/3A More Fuel pump questions. Triumph 10
