Please help ID this unusual [& beautiful] carburetor adapter
wlwhittier
I'll begin by stating that I don't know the adapter is even British!
But the quality indicates it may be; the odd angle adds to that impression, for me.
Specifications are as follows:
LARGE PORT DIAMETER: ~45MM
STUD SIZE: 8MM
STUD SPACING: ~85 X ~52MM
MOUNT FACE: ~105 X ~70MM
SMALL PORT DIAMETER: ~30MM
BOLT HOLE SIZE: ~8MM (CLEAR)
BOLT SPACING: ~92MM
MOUNT FACE: ~110 X 47MM
INCLUDED ANGLE: ~20 DEGREES
WEIGHT AS SHOWN: ~588 GRAMS
Thanks for your interest and comments! Warren
PAUL161
Pretty near impossible without any markings unless someone has one. Looks like a two barrel single carb adaptor to, whatever. Definitely angle head, V or slant in line. ?? PJ
CraigC
Looks like a VW air-cooled dual-port to Weber DCNF, or similar. Would need two to be of any use. No idea of make.
JPSmit
is there a number in the casting?
PAUL161
I would think a safe bet is it's for a VW. Two duel throat carbs were a popular conversion on hopped up VW engines. Here's another one from another manufacture. Naturally two are needed. From what I remember, most of that old after market VW stuff had no markings. Some even had angle adapters to level carbs. PJ
P Please help identify this tourer Spotted 13
Bayless Help please installing bonnet release cable Spridgets 8
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
6 Electrical Help Please Spridgets 7
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
N Please help --- New owner of a 1958 Austin Healey Sprite Spridgets 4
6 Master Cylinder Rebuild Help Please Spridgets 3
P A little identification help please Other British Cars 10
JPSmit Alternator help - please. Spridgets 21
M TR2/3/3A Please Help ID This Piston Triumph 6
H Help decoding Sprite’s VIN please Austin Healey 6
A TR2/3/3A Help with clutch and starter. Recomendatiins please Triumph 7
C Brakes....a little help please? Austin Healey 9
S TR4/4A Headlight switch wiring. Please help Triumph 2
bugedd HS4 mixture adjustment help please Spridgets 13
histerical Datsun tranny help please Spridgets 18
M TR2/3/3A Wheel Identification Help Please Triumph 7
Zimmycobra TR4/4A Need timing help - please! Triumph 15
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
davester Help me make some engine teardown/evaluation/might-as-well decisions please. Spridgets 6
G Need some help identifying some E-Type parts please -- Jaguar 4
N Please help identify this car Spotted 22
C Help me identify this Heater Box, Please Austin Healey 7
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
M TR4/4A Help with measurement please. Triumph 5
S Disconcerting engine noise, please help if you can. Austin Healey 56
M TR4/4A windscreen frame bottom rubber seal......help please. Triumph 3
M TR4/4A Microplas Surrey Top.....Window Help Please. Triumph 22
2billydavies TR2/3/3A help! again! please! starter motor Triumph 4
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
M TR4/4A TR4 Bumper Support Bracket...Help Please. Triumph 2
M TR4/4A Cover for trunk/boot spare wheel....help please. Triumph 9
L Healey 3000 restoration help and advice please... Austin Healey 18
M TR4/4A Vent lid rod...help please Triumph 3
M TR4/4A Door glass assembly help please. Triumph 2
M TR4/4A Switch plinth.....Help Please. Triumph 13
D Need help please Spridgets 4
D Need help please Austin Healey 2
I TR6 Caliper help please Triumph 2
C Heritage Certificate Interpretation help, please Austin Healey 13
J Help,help. please, with my brakes Austin Healey 7
I TR6 Need some electrical help please. Triumph 4
C Sway bar upper installation help please Austin Healey 3
I TR6 Electrical issues - please help. Triumph 5
I Help on installing side curtains and rag top on Bugeye please Spridgets 4
I TR6 69 TR6 courtesy liight wiring help please Triumph 5
I TR6 TR6 fender removal help please Triumph 10
I TR6 TR6 grill emplem help please. Triumph 16
