Please help --- New owner of a 1958 Austin Healey Sprite
Newb
Hello everyone, I'm a proud new owner of a 1958 Austin Healey Sprite. It is equipped with a 1275 BMC motor, 45 DCOE Weber, mild cam, tube header, Datsun 5-spd and front disk brakes.
I am having an issue with the RPMs upon start. It warms up fine to 160, but I have to give it gas the whole time. Then after a few minutes, it should settle at idle (1k RPMs?), but it sputters out and dies. Car was not driven much in the past 3 years. I filled tank with 91 Octane, but had about 2 or 3 gallons of old gas. Any ideas of what might be going on here? Where to start?
Very much appreciate any advice you may have!
Cheers!
Jerry A.
p.s. I have a short 2-min video posted to YouTube https://youtu.be/UK6EonBp-D0
Check the plugs. If they are fouled, put in a clean set and see how it runs. Then check them again and see if they indicate a problem.
Platinum
Congrats on a great 'base' to work with! A well set up 1275 in a Spridget chassis is something really special.
Even from the inherently poor quality of YouTube audio, it's apparent that thing is running wildly over-rich down at low end rev's. Compound that with old fuel and it's no surprise it runs that way.
I'd be curious to know how the Weber is jetted. A 45 is kinda overkill for a mildly set up 1275. A 40 would be more than adequate.
The oil pressure indicated in the video seems a bit "lazy" on revving, idle is good but it should be closer to 60~70 PSI nearly instantly on revving to 2800~3500 RPM. A modified oil pump may be the reason, more volume at lower pressure. Hunt for Clive Trickey's books on that, Good explanations and illustrations.
By all means, do some plug swaps, invest in a pair of "ColourTune" tools to help set up idle jets and mixtures with that Weber. Another thing to look at is the choke pistons in the carbs. Make sure they're fully seated. If not, they can leak fuel past the idle circuit.
N
Newb
Thank you guys for the great insight. As I said, I really am new to the circuit and have everything to learn (from scratch). I am by no means "qualified" yet (or brave enough) to attempt tinkering on this beauty, but have an appointment with a well-qualified British repair shop in San Marcos -- not too far from me in Oceanside. The shop owner did warn me not to run it any longer, until he gets his hands on it, to minimize any potential (further) harm. Here is a pic of the sickly Sprite...
Platinum
That alone gives an indication you may have a good place to take it. Keep us up on what goes on with it! Really curious as to what they have to say about the Weber jetting and the oil pressure. Be sure to show them your video.
P Please help identify this tourer Spotted 13
Bayless Help please installing bonnet release cable Spridgets 8
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
6 Electrical Help Please Spridgets 7
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
6 Master Cylinder Rebuild Help Please Spridgets 3
P A little identification help please Other British Cars 10
JPSmit Alternator help - please. Spridgets 21
M TR2/3/3A Please Help ID This Piston Triumph 6
H Help decoding Sprite’s VIN please Austin Healey 6
A TR2/3/3A Help with clutch and starter. Recomendatiins please Triumph 7
C Brakes....a little help please? Austin Healey 9
S TR4/4A Headlight switch wiring. Please help Triumph 2
bugedd HS4 mixture adjustment help please Spridgets 13
histerical Datsun tranny help please Spridgets 18
M TR2/3/3A Wheel Identification Help Please Triumph 7
Zimmycobra TR4/4A Need timing help - please! Triumph 15
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
davester Help me make some engine teardown/evaluation/might-as-well decisions please. Spridgets 6
G Need some help identifying some E-Type parts please -- Jaguar 4
N Please help identify this car Spotted 22
C Help me identify this Heater Box, Please Austin Healey 7
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
M TR4/4A Help with measurement please. Triumph 5
S Disconcerting engine noise, please help if you can. Austin Healey 56
M TR4/4A windscreen frame bottom rubber seal......help please. Triumph 3
M TR4/4A Microplas Surrey Top.....Window Help Please. Triumph 22
2billydavies TR2/3/3A help! again! please! starter motor Triumph 4
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
M TR4/4A TR4 Bumper Support Bracket...Help Please. Triumph 2
M TR4/4A Cover for trunk/boot spare wheel....help please. Triumph 9
L Healey 3000 restoration help and advice please... Austin Healey 18
M TR4/4A Vent lid rod...help please Triumph 3
M TR4/4A Door glass assembly help please. Triumph 2
M TR4/4A Switch plinth.....Help Please. Triumph 13
D Need help please Spridgets 4
D Need help please Austin Healey 2
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
I TR6 Caliper help please Triumph 2
C Heritage Certificate Interpretation help, please Austin Healey 13
J Help,help. please, with my brakes Austin Healey 7
I TR6 Need some electrical help please. Triumph 4
C Sway bar upper installation help please Austin Healey 3
I TR6 Electrical issues - please help. Triumph 5
I Help on installing side curtains and rag top on Bugeye please Spridgets 4
I TR6 69 TR6 courtesy liight wiring help please Triumph 5
I TR6 TR6 fender removal help please Triumph 10
I TR6 TR6 grill emplem help please. Triumph 16
