Help,help. please, with my brakes
jerseyjoe
Hi All,
I am new here but not new to playing with cars. My newest one is a 1967 BJ8 that needs some help. The first thing I am playing with is the bad booster. I have removed it and plan on replacing it sometime in the future. I want to by pass it for now but I am very confused. The booster had two lines that were attached to the brake system. One of the lines went to a T block that has the brake light switch and the other went to a junction block the has 3 lines attached. I thought all I have to do is run a lines from the light switch block down the the junction block. Easy? Well that appears to be a special line with different ends. Has anyone did this before??? Am I doing this wrong? Any help will be greatly appreciated..
Thanks,
JerseyJoe
SpacerM
Do you have a moss catalog? If not, you can look online ( I'm assuming you don't have the service manual which is handy for situations like these) but if you look at the Moss "brake pipes" page you can see that there is a three way pipe connector that connects the line from the master cylinder, the brake light switch and the servo on the "input" side of the servo, and the output of the servo then goes to a four way that distributes the brake fluid out to the wheels (with the line to the rears being the single line and each front getting its own line).
J
jerseyjoe
Thank you for the reply...the Moss picture is what I was trying to say. Thanks..but I need to install a pipe that connects the block that has the light switch to the 4 way block. How does one make it? What should the ends be...inverted flare? Sorry for all of the questions
Joe
Legal Bill
Don't you have the pipes that were attached to the booster? Just match the junction box ends of each pipe coming out of the booster with the ends of the pipe you are making.
steveg
Joe
I believe all the pipes (except at the servo) are inverted flares. Healey Surgeons will make custom pipes for around $25 each. Just tell them what you want to do. They'll know what flares you need, too.
Genos2
You can buy a basic tubing-cutting & flaring kit rather inexpensively at any auto parts store. As said they also sell varying lengths of pipe. After a bit of practice, it's quite easy to do. Why pay shipping & higher prices IMO.
GregW
Hi Joe,
Be aware that the master cylinders are different for boosted and non-boosted cars. So removing the booster without changing the master cylinder's diameter will result in greater effort to brake the car.
P Please help identify this tourer Spotted 13
Bayless Help please installing bonnet release cable Spridgets 8
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
6 Electrical Help Please Spridgets 7
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
N Please help --- New owner of a 1958 Austin Healey Sprite Spridgets 4
6 Master Cylinder Rebuild Help Please Spridgets 3
P A little identification help please Other British Cars 10
JPSmit Alternator help - please. Spridgets 21
M TR2/3/3A Please Help ID This Piston Triumph 6
H Help decoding Sprite’s VIN please Austin Healey 6
A TR2/3/3A Help with clutch and starter. Recomendatiins please Triumph 7
C Brakes....a little help please? Austin Healey 9
S TR4/4A Headlight switch wiring. Please help Triumph 2
bugedd HS4 mixture adjustment help please Spridgets 13
histerical Datsun tranny help please Spridgets 18
M TR2/3/3A Wheel Identification Help Please Triumph 7
Zimmycobra TR4/4A Need timing help - please! Triumph 15
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
davester Help me make some engine teardown/evaluation/might-as-well decisions please. Spridgets 6
G Need some help identifying some E-Type parts please -- Jaguar 4
N Please help identify this car Spotted 22
C Help me identify this Heater Box, Please Austin Healey 7
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
M TR4/4A Help with measurement please. Triumph 5
S Disconcerting engine noise, please help if you can. Austin Healey 56
M TR4/4A windscreen frame bottom rubber seal......help please. Triumph 3
M TR4/4A Microplas Surrey Top.....Window Help Please. Triumph 22
2billydavies TR2/3/3A help! again! please! starter motor Triumph 4
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
M TR4/4A TR4 Bumper Support Bracket...Help Please. Triumph 2
M TR4/4A Cover for trunk/boot spare wheel....help please. Triumph 9
L Healey 3000 restoration help and advice please... Austin Healey 18
M TR4/4A Vent lid rod...help please Triumph 3
M TR4/4A Door glass assembly help please. Triumph 2
M TR4/4A Switch plinth.....Help Please. Triumph 13
D Need help please Spridgets 4
D Need help please Austin Healey 2
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
I TR6 Caliper help please Triumph 2
C Heritage Certificate Interpretation help, please Austin Healey 13
I TR6 Need some electrical help please. Triumph 4
C Sway bar upper installation help please Austin Healey 3
I TR6 Electrical issues - please help. Triumph 5
I Help on installing side curtains and rag top on Bugeye please Spridgets 4
I TR6 69 TR6 courtesy liight wiring help please Triumph 5
I TR6 TR6 fender removal help please Triumph 10
I TR6 TR6 grill emplem help please. Triumph 16
