TR6 Question on new wiring harness
nichola
Bronze
Installing the new harness has been easy everywhere except under the dash. Even under dash is not so bad except the crazy array of light bulb holders. For example the speedo and tach appear to get illumination from two bulbs but the harness seems to have just one for each. And of course my wiper switch (1973 vintage) doesn’t work. But the question right now is what is this bullet connector (pic) at the voltmeter supposed to connect to? If I look at diagram it seems like it should be for the brake fail lamp but that lamp already has white and black/purple wires going into it from the harness.
If it’s just hanging around being available I would hook my TBI to it as that requires 12v in run and cranking positions.Thanks for any and all tips.
Madflyer
It looks like they needed to put it somewhere as not to lose it It's not for the Volt gauge. If the harness was made for more than one model year I could not find it. Did it come from the fuse block or the key switch
nichola
nichola
Bronze
Thanks Madflyer, I am not sure where it's coming from but I'm going to ground the brake fail switch and see if the lamp lights up. If it does I'll use the bullet connector for the TBI.
I will lay out the old harness and try to figure out the rest of the gauge lighting from there.
nichola
nichola
Bronze
Oops, I labeled the wrong white wire “volt gauge” and found the right one. It’s two whites going into a female connector, as it should be. So, the white with the bullet piggy-backed must be a harness accommodation for a different year. But since I have the floor...
On the wiring diagram, what is the circle in the middle of the line? The arrow is pointing at it in the attached photo.
thank you
RGK
A circle is one pin of the ignition switch multipin connector. The solid circle is usually a spliced wire connection. Masters electrical maintenance book is highly recommended.
mctriumph
I have a book of all the different tr6 harnesses used , 69 and 70 were the only years that were
the same. I also have never seen a new harness that did NOT have at least one problem/inaccuracy.
That said ,often the OE harness is mostly in need of new connectors and di-electric grease to be of
good kit.
MD(mad dog)
Rod-H
Bronze
Agree with MD, I always buy a dozen or so bullets and connectors additional when sorting a new harness.
Rod
ckeithjordan TR2/3/3A Wiring Harness Question[s] Triumph 10
C MGA Wiring harness question MG 7
Griz Rear Wiring Harness Question Austin Healey 6
B Question on OD wiring harness 57 Smallmouth Triumph 15
B wiring harness question: Triumph 3
Tinkerman TR2/3/3A Wiring Harness Question on my TR3A Triumph 8
Bone wiring harness question` Spridgets 1
bighealeysource BJ8 wiring harness question Austin Healey 8
M MGB 1970 MGB roadster wiring harness question MG 0
B TR4/4A Basic Wiring Question Triumph 35
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
R TR6 Starter wiring question Triumph 6
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
JPSmit Todays question - wiring Spridgets 14
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
BoyRacer Wiring question for alternator conversion Austin Healey 3
G TR4/4A Front Parking Lamps Wiring Question Triumph 5
T TR2/3/3A Question on wiring Denso alternator through ammeter Triumph 4
Griz Trafficator Wiring Question Austin Healey 16
Michael Oritt Wiring question Austin Healey 5
N Spitfire alternator wiring question Triumph 1
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
J TR6 '73 TR6, Wiring Question. Original Owner Triumph 5
AngliaGT '74 Midget - Wiring Question Spridgets 2
Willie_P TR4/4A WIRING question: gear reduction starter Triumph 3
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
TomChar TR6 '74 brake failure / oil pressure / ARV wiring question Triumph 19
B TR6 Wiring question Triumph 11
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
D Original BN6 / BN7 Battery Switch Wiring Question Austin Healey 15
T BN-1 Wiring Question Austin Healey 3
Griz Another BJ7 Wiring Question Austin Healey 4
M Quick tachometer wiring question on a '65 Spridgets 10
Tugboat Wiring Question Triumph 6
glemon Wiper Motor Wiring Question Triumph 11
bash Alternator wiring question Triumph 5
B Another wiring question 57 smallmouth control head Triumph 2
Tinkerman TR2/3/3A Wiring question TR 3A Triumph 4
T TR4/4A White wire question on TR4A A-type wiring Triumph 2
Tinkerman TR2/3/3A Wiring question TR3A Triumph 5
M_Pied_Lourd TR2/3/3A TR3A Gauge Cluster Wiring Question Triumph 7
R TR2/3/3A TR3 Headlight Wiring Question Triumph 6
R Wiring question. No spark, need help. Spridgets 16
Coyote1 Overdrive wiring question Triumph 8
T Wiring hack - iginition switch question Spridgets 8
E BE Alternator Wiring Question Spridgets 5
hondo402000 TR6 Another TR6 wiring question Triumph 5
hondo402000 TR6 TR6 Wiring/amp gauge question Triumph 8
