TR6 73 TR6 Temp Gauge Wiring Question
Jerryny
Afternoon all
Question: On a 73 TR6 Temp Gauge, which spade does the Green/Blue wire connect to when looking at the Temp Gauge from the rear? Left or right
Thanks
Gliderman8
I think it goes on the left. It's the ground wire. I'm not sure it will do any harm if it's reversed. "GU" is the Green/Blue wire
J
Jerryny
My GU is on the right when looking at it from behind. Maybe that's what's frying my voltage stabilizer. Fuel gauge works fine. I want to make sure before I hook up the GU wire again and lose my last voltage stabilizer
Gliderman8
Without actually looking behind my dash, I was just taking a guess.
Maybe someone that has access to their gauge will post what they have.
poolboy
From the indispensable Dan Master's book in Chapter 15 "GAUGES" he writes under the "Polarity Concerns" topic:
"Being thermal devices, neither the voltmeter, the fuel level gauge, nor the water temperature gauges are polarity sensitive. That is you can connect them up either way and they will still work just fine"
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
T TR6 High temp paint required for TR6 valve cover? Triumph 13
N TR6 Desired TR6 engine coolant temp? Triumph 7
jerrybny TR6 TR6 Engine Temp survey Triumph 22
jerrybny TR6 Continuing Saga of TR6 Temp Triumph 19
jerrybny TR6 Normal running temp for TR6 Triumph 13
Hawk813 TR6 TR6 Brakes Triumph 4
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
