TR6 73 TR6 Temp Gauge Wiring Question
Jerryny
Afternoon all
Question: On a 73 TR6 Temp Gauge, which spade does the Green/Blue wire connect to when looking at the Temp Gauge from the rear? Left or right
Thanks
I think it goes on the left. It's the ground wire. I'm not sure it will do any harm if it's reversed. "GU" is the Green/Blue wire
My GU is on the right when looking at it from behind. Maybe that's what's frying my voltage stabilizer. Fuel gauge works fine. I want to make sure before I hook up the GU wire again and lose my last voltage stabilizer
Without actually looking behind my dash, I was just taking a guess.
Maybe someone that has access to their gauge will post what they have.
From the indispensable Dan Master's book in Chapter 15 "GAUGES" he writes under the "Polarity Concerns" topic:
"Being thermal devices, neither the voltmeter, the fuel level gauge, nor the water temperature gauges are polarity sensitive. That is you can connect them up either way and they will still work just fine"
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
T TR6 High temp paint required for TR6 valve cover? Triumph 13
N TR6 Desired TR6 engine coolant temp? Triumph 7
jerrybny TR6 TR6 Engine Temp survey Triumph 22
jerrybny TR6 Continuing Saga of TR6 Temp Triumph 19
jerrybny TR6 Normal running temp for TR6 Triumph 13
tr6web TR6 TR6 Manifold gasket help Triumph 0
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 5
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
