TR2/3/3A 1954 TR-2 O.D. Wiring
Redoakboo
I have two O.D. harnesses for my 1954 TR-2.
#1 Has two wires, they are Yellow and Yellow/Green
#2 has four wires, they are Yellow/purple, Yellow/Green,White and Brown.
The Yellow/Green is duplicated in both harnesses.
RELAY- C-1 connects to Amp Meter-Brown
C-2 connects to O.D. Solenoid -Yellow/Purple
W-2 Connects to O.D. Switch -Yellow/Green
W-1 connects to starter solenoid or Fuse A3 -White
O.D. switch connects to Isolation switch - Yellow
Do these look correct? I am confused with the fact that both harness have a Yellow/Green wire? Does it matter which one you use? I plan on connecting the White wire to the starter solenoid as i read this should not be a fused connection?
Thanks, Dick
sp53
Sounds like one is more complete than the other follow the wiring diagram and see what is extra. I would like to be more helpful, but my OD is not tested yet. I have been working on my truck, but should get back to the tr3 soon. There will always be a polarity to follow, but I do remember the switches on the trans confused me. I would think you want the fuse; I put one in line. There should be more OD wiring stuff in the “way back machine” of the forum. Type it in the search box and see what you get.
Jim_Stevens
You need them both— check the wiring diagram. Jim
DavidApp
I added 2 new fuses for my OD supply. 1 is for the solenoid side which helped me discover that the pull in coil was staying energized as it blew a 10 amp fuse. The other protects the OD relay coil plus my USB supply and heater.
Where did you get the OD harness?
Looking at the wiring diagram done by Auto wire you can see the
White wire goes to W1 on the OD relay.
Brown/White goes to C1 on the OD relay.
Yellow /Green goes to W2 on the OD relay.
Yellow/Purple goes to C2 on the OD relay
Yellow/Purple continues to the OD solenoid.
Yellow goes to the Transmission interlock via the dash OD engage switch. The Yellow/Green from W2 goes to the other side of the dash OD engage switch.
I did a bit of my own thing with the wiring on the OD.
Hope this is not too confusing.
David
R
Redoakboo
David
Thanks David,
Did you just add inline fuses?
Dick
DavidApp
Not in line. I did a small fuse block and relay. The relay is for the heater and USB. That way I do not forget to turn the heater off.
David
R
Redoakboo
Thanks David,
Dick
I got the harness from Moss. Looks like I have all the right connections, according to your message. Question about the fuses.I assume you made the fuse connection on the Yellow/purple line between C2 and the solenoid. Where was your second fuse connection? between the brown or the white wires?
Dick
DavidApp
My fuses are before the OD Relay. The white wire goes to W1 and has the 5 amp fuse. The brown wire goes to C1 and has the 10 amp fuse. That was the fuse that was blowing and made me realize that my OD solenoid was nor working correctly. The pull in coil should switch off and the holding coil takes over. The pull in coil takes a lot more power and will damage the solenoid if it stays energized too long. There is an internal switch that does the change over.
Using an Amp clamp meter I could see it was not doing its job. I managed to fix the internal switch. I got a new solenoid just to be sure.
David
R
Redoakboo
David
I ordered a inline fuse pack and will fuse the white and brown wires. I never use a heater here in Orlando, so will probably skip this fuse.
Thanks for you help. Dick
R TR2/3/3A Wiring 1954 TR-2 Triumph 12
R TR2/3/3A Color Wiring Diagram-1954 TR-2 Triumph 1
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
W For Sale 1954 Nash-Healey Le Mans Coupe Other British Classifieds 2
PAUL161 T-Series Rare 1954/55 MGTF Accessory MG 23
F 1954 MG TF for sale, ready to drive and show MG Classifieds 1
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1954 Austin Healey 100-4 Beautiful Restoration Austin Healey Classifieds 0
P For Sale 1954 100 Factory M Austin Healey Classifieds 4
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
R TR2/3/3A Re-building 1954 TR-2 engine Triumph 20
R TR2/3/3A Re-assembling 1954 TR-2 Engine Triumph 25
R TR2/3/3A 1954 TR-2 Engine Triumph 9
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
W Differential oil for 100/4 1954 Austin Healey 14
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
aero3113 1954 Nasty Boy Austin Healey 14
bcliff For Sale 1954 Riley RME Saloon for sale Other British Classifieds 3
I 1954 BN1 - Bump Rubber [shock stopper] wrong length?? Austin Healey 8
C Recommendations on where to send my 1954 BN1 for metal work? Austin Healey 13
A 1954 100/4 Engine specs Austin Healey 2
T 1954 100-4 in my garage Austin Healey 22
C TR2/3/3A 1954 tr2 Triumph 5
L Why won't my steering wheel turn on my 1954 100/4 BN1? Austin Healey 14
C 1954 100 Project Austin Healey 93
D TR2/3/3A 1954 TR2 long door for sale Triumph 0
C T-Series 1954 MGTF [not the new TF] gearbox MG 4
britlover What is a completely original 1954 100-4 worth? Austin Healey 46
TR6BobNF TR2/3/3A 1954 California Blackplate TR2 Triumph 14
Grannieannie 1954 Austin A40 Somerset Other British Cars 17
T Bonneville 1954 Endurance World Record Video Austin Healey 0
Frankenhealey Bearings & Oil Seals for a 1954 Austin Healey BN-1 Austin Healey 0
D March Field, 1954 Racing 0
D Torrey Pines, 1954 Racing 8
PAUL161 T-Series 1954 TF Question. MG 15
bighealeysource single 12 volt battery conversion on a 1954 BN1 Austin Healey 9
V TR2/3/3A Looking for 1954 TR2 engine Triumph 6
bighealeysource Questions about a 1954 100-4 Austin Healey 8
Russ Austin "WOW" 1954 SWALLOW DORETTI on Ebay Triumph 19
NutmegCT TR2/3/3A Tom McCahill's 1954 review of the TR2 Triumph 6
PAUL161 T-Series What would you give for a 1954 TF? MG 10
I Carb Overhaul for retro fitted 1954 100M Austin Healey 1
R 1954 Zodiac Zephyr Other British Cars 0
BrettSutherland 1954 Austin Healey LeMans VIN BN1L152555 Austin Healey 0
1 T-Series Judson Supercharger for 1954 MG TF MG 7
Moose33 1954 Chevy Other Cars 2
Steve 1954 Sunbeam Alpine MK III Roadster on eBay Sunbeam (Rootes) 3
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
