Questions about a 1954 100-4
bighealeysource
Bronze
Hey all,
Have a few questions about a 100-4 I just purchased and thought this group might be able to help !
1. This has the non adjustable wheel with the trafficator
and directly above the steering column on the dash has three
about 1/2 inch round "idiot lights". The one in the middle
actually has "traf" that lights up when the turn signal
lever is engaged either left or right. Have not seen any pictures of this in any articles about 100-4's and was just curious as to its originality.
2. Has a cold air box with the body number and engine number
engraved on it in same font used on other tags, areas. Also
has the body number engraved on the cockpit surround pieces.
The font on the moldings is identical to that on the cold air
box. Has louvered bonnet but no body number engraved on the edge as on actual BN2 100M's. Also has a Westlake head.
3. Not suggesting at all that this is a factory 100M as
been in touch with Bill Meade of the 100M Registry, but does
anyone have any ideas as to the significance of this July 2,1954 build date BN1 having the markings and partial LeMans
kit pieces as described above ? They certainly appear to have
been engraved/stamped at the Healey works but the Heritage
Certificate does not mention anything about this possible option. If not for the stampings I would simply assume it
was added by a previous owner or a dealer. Or someone took
great care to match the font on the stampings.
Look forward to hearing some opinions about this.
Thanks,
Mike
bighealeysource, you should google "forever healeys" he has a page dedicated to identification numbers and locations, also austin healey club of america gives a discription of the 100m. doing a google on "a.h. 100m" youll find lots of stuff. typically an unstamped louvered bonnet was indicative of a dealer installed 100m kit. id like to know and im sure others here also would be interested in hearing/seeing picts etc. of the car. :thumbsup:
bighealeysource, is your cold air box made of aluminum or steel?, do the carb. bodys have hand etched numbers including an "x"?, im also wondering if the high compression pistons had been installed. the numbers on the cockpit surround are typical, the indicator light configuration is one ive never seen on any other healey. :savewave:
glemon
The Weslake on the head is standard, does it have a bend in the x bracing in front of the radiator where the cam would go in if one were changing cams without pulling the motor?
bighealeysource
bighealeysource
Bronze
Hey y'all,
Thanks for the info back so far - knew I would get good feedback. I'm going to
look into the questions you have raised so far and will get back to you. I have
a picture of the unique dash "traf" light which I will see if I can post. It's
lit up in the picture as had the turn signal engaged. Will include a picture of
the cold air box too.
Is it common on all BN1's for the cockpit molding to be numbered with the
body number ?
Thanks,
Mike
not sure how to post so will put some on a shutter fly link and list that here.
zblu
bighealey source,
On my Nov '53 the body number is stamped (using 3/8-7/16 stamps from memory) into the cockpit moldings as well as the other usual places, including the side of the ali bonnet, one of my "X" braces had been almost totally removed!, (must have been for real fast cam changes!), the traf light and extra holes sound like improvements in the eye of a previous owner.
And here is food for thought, if you renewed/refurbished the car with new panels, mouldings etc none would be stamped and the only remaining points of identification would be engine number and compliance plate
bighealeysource
bighealeysource
Bronze
Hey all,
I took a few pictures of the cold air box installed on
my BN1 as well as the infamous trafficator signal light
that lights up "traf" when the turn signal is engaged.
Did determine that the cold air box is aluminum and that the
bonnet reinforcing is welded in the middle as on Forever
Healey's website info about his LeMans restoration.
Could not tell if the x bracing was altered - need a better
flashlight !!!
Put some pictures on Shutterfly so if you go to:
austinhealey1954bn1.shutterfly.com
to can see the pictures of the above.
Thanks,
Mike
glemon
Mike, I can't figure out how to get into your account without a password, don't know about shutterfly, but photobucket lets you copy either a link to your pics or the html code to insert the pic into your post on forums like this one--that might work better, would love to see the pics, used to have a BN1.
Greg
bighealeysource
bighealeysource
Bronze
Hey Greg,
My mistake, corrected the website address to:
If you enter that it will take you to the pics. Just a few up right now but
will add some later.
Regards,
Mike
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K General MG 1968 Midget Questions MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W General Tech 2500S starter motor and fuse box questions Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
P MGB 1980 MGB carb and oil questions MG 3
C My 2500M progress/questions thread TVR 5
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
B TR4/4A Dumb Bumper questions Triumph 4
B Two questions about Bugeye floor panel weld drilling Spridgets 15
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
R TR6 Questions on emission tank-to-canister pipe Triumph 0
AngliaGT MGB-GT Couple of Dumb Questions - '67 GT MG 11
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
D TR2/3/3A More Fuel pump questions. Triumph 10
K TR2/3/3A Hard start questions.... Triumph 4
F TR2/3/3A back half to chassis questions Triumph 105
D Carpet Questions Austin Healey 2
J TR6 73 TR6 Static Timing Questions Triumph 6
glemon Spitfire Spitfire Questions Triumph 7
B TR4/4A General exhaust questions Triumph 17
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
Pythias Springs and ride height... Questions. Spridgets 2
L TR2/3/3A Engine removal questions Triumph 8
I Brake rod questions Spridgets 7
J TR6 2 Brake Questions Triumph 3
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
K TR2/3/3A Couple of choke questions Triumph 1
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
T TR2/3/3A Questions on fuel pump installation Triumph 7
C Non-Adjustable steering column questions Austin Healey 14
I Bugeye electrical questions Spridgets 17
Bayless Master cylinders questions Spridgets 7
B Seat Slide Installation Questions Austin Healey 14
Rut TR4/4A Rear end questions Triumph 8
P TR2/3/3A Chassis paint questions Triumph 8
R Jensen-Healey Fuel Tank Questions Other British Cars 17
doc50 1958 Nash metro door questions... Other British Cars 6
P TR2/3/3A TR2 color questions Triumph 23
steveg Holley fuel regulator questions Austin Healey 17
R Dash Install questions Austin Healey 31
T Tri-carb questions. Austin Healey 10
KVH General TR Type A Laycock Overdrive Questions Triumph 8
P BJ7 Carpet Install Questions Austin Healey 29
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
M Chrome wire wheel questions Spridgets 5
Y MGB Answer to a question creates more new questions.... MG 12
Y MGB First of probably many questions - driveshaft transplanting: MG 3
