    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Dash Install questions
RestoreThemAll
I removed the dash to install leather. Turned out real nice. Lost a month waiting for parts, including the trim felt.
The best part of this story is that my granddaughter helped me install the dash! Keeping the youngest gen interested!
Questions:
1) Should the chrome instrument ring be touching the sheet metal? See pic.
2) Should dash fit tight to the sheet metal. See dash gap pic.
3) Note the holes in the sheet metal. What are they for? There are no holes in the dash that would line up.
Other than that how does it look?
Dale
Unless I stumble onto another picture, this is the closest I can come to what you're asking. The shroud is already fitted/painted in this shot, and the chrome trim around the fascia has not yet been fitted, but elevation-wise, doesn't look far off from where yours is.
It does look a little tight on the RH side__your 2nd pic__but if the holes in the dash and on the curved A-pillar piece line up, that must be where it goes...
... assuming that's the same dash that came out of the car. The dash shown in my pic below was not the original, but had fewer non-stock holes in it (I had to fit the lighter, as my original choke was under the steering column, not like the later cars; my w/washer took the choke hole, and NO CHOKE NEEDED with Webers).
You'll also notice that I didn't cover the dash with vinyl, preferring the same exterior paint and an engine-turned finish for the instrument panel.
Edit: a few more pictures taken once completed (widely understood to be a relative term...)
R
RestoreThemAll
Hi Randy. Yes, the dash is original to the car.
So looking at your dash, the holes are for riveting theshroud on.
I also agree with Bob. Test fit the shroud. I’ll have a busyweekend. Good day to work inside. It snowed here with plenty more on the way.
R
RestoreThemAll
I test fitted the shroud and top dash last night. The shroud does touch the dash chrome. It doesn't look too bad until the top dash is in place. It's all original to the car except the top piece. I don't see any way to change it so I'll have to live with it. See pics. Unless the BCF experts have advice?
The rivets will pass through and press hard on the dash leather. The old cover has holes cut to prevent tearing I guess.
I should probably drill new holes, as the old metal is torn?
I don't recall what the rivets look like. Are they a special rivet/tool?
Dal
British_Recovery
Bronze
Dale,
In the photo of the dash with the steering column coming through, it looks like the dash could be lowered a bit to center the column through the hole. If the column is in the correct position ( there are adjustments with the mounts ), use it to position the dash lower if called for. On the dashes I have off cars, the rivet marks are into the vinyl right on the curved edge along the top. You can drill new holes for the shroud and I would use aluminum pop rivets just long enough to get a bite.
Bob
steveg
Dale,
Bob
Bob - could you clarify? Why would you need to lower the dash when the steering column position is adjustable?
The rear steering column mount is adjustable in its mounting bolts for height. The box front mounting bolts allow swiveling and the two air sealing plates can be adjusted.
British_Recovery
Bronze
Not knowing what has been changed on the car, I suggest possible adjustments to keep the column and dash opening centered. This could include adjusting the column, as Steve describes.
Bob
R
RestoreThemAll
How would one lower the dash? The mounts on each side are solid. I don't think that they'd bend well. The screw holes are not slotted.
Dale
vette
I suppose I would do any adjustment necessary to make it all work but there are two things I see in your photos that give me questions. One is that the padding you are using for the dash top pad might be a little thick which when wrapped around the front edge might be contributing to the shrouding of the chrome trim around the gauges. The other thing I noticed is that in my restoring of my BJ7 I do not remember having at any time putting in rivets along the top of the dash. My rivets are there but that is not what is holding the dash in place. The dash i believe is only held in place via the side pieces and one bolt near the center which goes thru the brace. I deliberately uncovered my dash because I like the painted surface. Some pics for reference.
R
RestoreThemAll
Vette, you are correct. The rivets hold the shroud not the dash. The shroud rivets do hit the top of the dash but don't pass through.
The padding is thick. Good point.
Your dash is beautiful!
R
RestoreThemAll
Nice BJ7 Rick. Well that makes me feel better. Maybe some of these cars are designed weird.
I may try a washer or two between the dash and dash mounts. That would drop the dash and buy just enough to make the Chrome not rub on the sheet metal above.
vette
Here is just another pic for reference of end pieces:
John Turney
On my BN4, I can see the entire trim oval when sitting in the seat. There is also space between the top of the dash and the shroud, maybe 1/8" minimum in the center. My shroud wraps around to meet the roadster doors at the ends, and I can get my fingers between between the dash top and shroud/dash pad.
vette
R
RestoreThemAll
I had some good luck this weekend. The steering wheel mount under the dash has slotted holes. I loosened the bolts and lifted the scuttle. It moved less than an 1/8 inch. Thanks for that tip Bob!
I also took a little metal off the holes on the sidemounts. Less than 1/16 inch.
Those two changes dropped the dash and aligned thesteering column with the dash hole. See attached.
The puffy padding on the dash top will cover the chrome ring slightly but I can live with that.
R
RestoreThemAll
I also put the dash back together. It's always fun to work under the dash.
The actual color of the leather is a deep cherry. Pic isn't the best.
longbridgehealey dash top install Austin Healey 0
DNK Dash install Triumph 9
S BJ8 Dash install tool? Austin Healey 5
G Install Bugeye dash in my 67 Midget Spridgets 0
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A Dash color Triumph 9
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
I TR6 Thickness of original TR6 dash Triumph 2
S TR2/3/3A Dash Pot Oil Triumph 14
TRMark T-Series Dash for Sports/Racer MG 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
TomMull replacing walnut veneeron the dash Lotus 17
K TR2/3/3A Dash Lights Triumph 3
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
