    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
dash top install
OK, I've recovered my dash and replaced it, and I've covered a dash top for it (100-6 longbridge BN4). Since it was missing the dash top to begin with, I'm unsure of all of the connecting points. Here's what I think - two screws in center that hold the rear view mirror on, and then one screw on each side coming down through the top, right behind the tonneau mounting posts.
Am I right? Any helpful hints for the install?
Thanks
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
EWD TR6 TR6 top dash trim paint Triumph 2
wangdango BJ8 dash top redo? Austin Healey 1
JimTR4 TR4/4A Top dash pad vinyl is "puffy" Triumph 2
T TR4/4A Attaching top dash pad on a Tr4a Triumph 8
BOBBYR BJ8 top dash pad removal Austin Healey 9
Jeepster BJ8 padded dash top Austin Healey 1
Boggsy64 MGB Dash Top Repair Panel MG 6
R BN7 / BJ7 Dash Top Removal Austin Healey 11
M Dash top Austin Healey 4
Xte Original covering center dashboard and top dash ? Austin Healey 5
KVH TR4/4A New Dash Top TR4 Triumph 2
chicken Help fitting and covering a dash top assembly Austin Healey 7
longbridgehealey dash top installation Austin Healey 0
chicken Dash top assembly for a BJ7 Austin Healey 1
jjbunn Dash Top Removal Triumph 32
J Spitfire Spitfire Dash Top refinishing Triumph 4
TR674 Crash Pad [dash top] Triumph 3
A Source of Vinyl for padded dash top Bj8? Austin Healey 1
B Rotten Dash Top Wood Austin Healey 11
B Dash Top Re-Covering Austin Healey 5
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
