Help fitting and covering a dash top assembly
chicken
I have a BJ7 and have just purchased a plain (un-trimmed) dash top assembly, can anyone supply any photo's that i can give to my trimmer guy to work to ?
Also as the dash top was never fitted when i first had the car i could do with some guidance on fitting procedure, there are two holes in the center which i guess the rear view mirror scrws through but what about on the ends.
Rob
I just finished covering the dash top on my 100-6, and the fit was so tight that the two screws that attach the rear view mirror were sufficient to keep it in place. However I have heard of some sort of clip that goes on either end of the dash top, but I haven't seen one.
GregW
Hi LB,
Here is a shot of the clip.
GregW
Hi Rob,
Here are some photos for my BJ8. Moss list the dashpad as the same part # for the BJ7. The small tear in-between the demisters on the top photo is the hole the windshield bolt goes through. You can see the type of foam used in the second shot. This looks like 1/8" foam, which also covers the top under the vinyl. The edge that faces the driver had a piece of 1/2 round. Not really foam, but not styrofoam either.
Hi, GregW - that's about how I figured it would look. When I recovered my dash and top, the top was such a snug fit at either end that I didn't persue finding the clips any further. I guess if it loosens with age I'll have to find them and attach. Thanks for the pic!
chicken
chicken
Greg
I see you have some foam on the back of the panel where the demisters come through, is this to stop it rubbing on the paintwork?
Also on the front edge you mention 1/2 round foam, i assume this covers the small 1" wooden strip which in turn is covered by the vinyl?
On my panel at either end there are two metal shaped pieces, from what i can figure these just fit over the edge of the shroud at both ends, are they riveted/screwed there at all or is it simply the rear view mirrow bolts that hold it in place?
I would post a pic of the new top panel but i havn't a clue where to start.
Rob
GregW
I guess, probably also to make a better seal. That way the high powered heater won't blast air up underneath the dash pad.
Yes
If memory serves me, the two clips (in my first photo) and the mirror are what hold the pad in place.
There is a file size limitation depending on what subscription you have (that would be 100k for you). When you are making or replying to a post, you'll see "File Manager" below the post window. Click that, choose "Browse" and navigate to where the picture is on your computer. Select it, and when you get back to the previous screen click "Add File". After a couple seconds, the file will appear at the top of the file manager window. Click "Done Adding Files" and your done.
DerekJ Fitting Moto Lita - HELP Austin Healey 6
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
