T-Series 1954 TF Question.
PAUL161
Can an OD transmission be installed in a 1954 TF without modifying the body? What's the options, if any? PJ
Steve_S
Should be possible, but you will need to fabricate rear mounts for the gearbox, and the tunnel will need to be wider. I don't recall what the tunnel is made of on a TF, steel or rubber. I know a guy with an LH-Type OD in his TD but the tunnel is not installed at the moment.
drooartz
Don't know about a LH-style overdrive, but there are a couple conversions out there for a 5-speed. Skyhook uses a Datsun transmission (similar to the one used for Spridget 5-speed swaps), and there's another that uses the Ford T-9 (I believe). Swapping in a taller rear end from an MGA is also popular.
PAUL161
PAUL161
I'm trying to get in touch with this guy who has one for sale. The price is right for what he claims is an older restoration. He claims the engine and gear box was completely rebuilt about 2,000 miles ago and a photo of the car shows it in real nice condition with it's original wire wheels. I'm just not in favor of a screaming engine while driving 55 to 60 mph, so I'm just gathering info in case we can make a deal. Thanks for the input. PJ
Steve_S
FWIW, I drive my '49 TC all over the west coast, sometimes 2-3K miles at a time, and sometimes with stock TDs and TFs following along. The TC has a stock engine and gearbox with slightly higher rear end gearing. The engine does just fine. If the TF is a 1500 then you will have more power than my car, so perhaps a gearing adjustment would be enough. Installing an MGB gearbox would certainly detract from the value of the car, if that matters to you.
As much as I prefer period-correct parts, a 5-speed would likely be a much easier conversion if you want more than four gears.
drooartz
The gearing certainly wouldn't keep me from buying any T-series MG (among my favorite designs of all time). You do have good options if you later decide you need to modify things.
PAUL161
PAUL161
Well, long story short, It was sold before I could get to it. The way it sounds, it was sold before the ad came out. That's the second one so far I lost. Oh well, disappointed, but I'll find one, in the right condition and at the right price. Right now, I only want a TF, but I want it close enough to me where I can go see it. Thanks for the tips guys. Your information is well received. PJ
Oh Steve, I too like period correct cars. That's why I asked if the transmission could be changed without any modifications to the body. I would never chop into a car to do that, regardless of how minor a change would be needed. If a taller rear would work and it was a bolt on operation with no other modifications, I might consider it. It's all info for my disintegrating memory banks. :jester: Thanks. PJ
Steve_S
I believe the TF will accept Midget gears, so no mods necessary. I put TA gears into my TC to achieve a slight decrease in RPMs at high speed. I would like to go higher but I don't have the engine to push it. Maybe next engine build... :smile:
PAUL161
PAUL161
I know that individual wood parts are available by the piece, but is there an out let for a complete wood kit for a TF? Not that this will be needed, but just in case. From what I've heard, a TF left outside for an extended period of time will eventually get wood rot, any truth in this? If I remember correctly, there was a guy at G-burg in 06 selling all kinds of wood kits. PJ
PAUL161
PAUL161
Anyone know the overall width and length of a 1954/55 TF? PJ
JPSmit
PAUL161
PAUL161
tdskip said:
Darn, JP beat me to that line...
If it will fit you kinda have to buy one you know...
That's what I keep telling myself! (Grin) :jester:
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
W For Sale 1954 Nash-Healey Le Mans Coupe Other British Classifieds 2
PAUL161 T-Series Rare 1954/55 MGTF Accessory MG 23
R TR2/3/3A 1954 TR-2 O.D. Wiring Triumph 9
F 1954 MG TF for sale, ready to drive and show MG Classifieds 1
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
R TR2/3/3A Wiring 1954 TR-2 Triumph 12
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1954 Austin Healey 100-4 Beautiful Restoration Austin Healey Classifieds 0
P For Sale 1954 100 Factory M Austin Healey Classifieds 4
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
R TR2/3/3A Re-building 1954 TR-2 engine Triumph 20
R TR2/3/3A Re-assembling 1954 TR-2 Engine Triumph 25
R TR2/3/3A Color Wiring Diagram-1954 TR-2 Triumph 1
R TR2/3/3A 1954 TR-2 Engine Triumph 9
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
W Differential oil for 100/4 1954 Austin Healey 14
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
aero3113 1954 Nasty Boy Austin Healey 14
bcliff For Sale 1954 Riley RME Saloon for sale Other British Classifieds 3
I 1954 BN1 - Bump Rubber [shock stopper] wrong length?? Austin Healey 8
C Recommendations on where to send my 1954 BN1 for metal work? Austin Healey 13
A 1954 100/4 Engine specs Austin Healey 2
T 1954 100-4 in my garage Austin Healey 22
C TR2/3/3A 1954 tr2 Triumph 5
L Why won't my steering wheel turn on my 1954 100/4 BN1? Austin Healey 14
C 1954 100 Project Austin Healey 93
D TR2/3/3A 1954 TR2 long door for sale Triumph 0
C T-Series 1954 MGTF [not the new TF] gearbox MG 4
britlover What is a completely original 1954 100-4 worth? Austin Healey 46
TR6BobNF TR2/3/3A 1954 California Blackplate TR2 Triumph 14
Grannieannie 1954 Austin A40 Somerset Other British Cars 17
T Bonneville 1954 Endurance World Record Video Austin Healey 0
Frankenhealey Bearings & Oil Seals for a 1954 Austin Healey BN-1 Austin Healey 0
D March Field, 1954 Racing 0
D Torrey Pines, 1954 Racing 8
bighealeysource single 12 volt battery conversion on a 1954 BN1 Austin Healey 9
V TR2/3/3A Looking for 1954 TR2 engine Triumph 6
bighealeysource Questions about a 1954 100-4 Austin Healey 8
Russ Austin "WOW" 1954 SWALLOW DORETTI on Ebay Triumph 19
NutmegCT TR2/3/3A Tom McCahill's 1954 review of the TR2 Triumph 6
PAUL161 T-Series What would you give for a 1954 TF? MG 10
I Carb Overhaul for retro fitted 1954 100M Austin Healey 1
R 1954 Zodiac Zephyr Other British Cars 0
BrettSutherland 1954 Austin Healey LeMans VIN BN1L152555 Austin Healey 0
1 T-Series Judson Supercharger for 1954 MG TF MG 7
Moose33 1954 Chevy Other Cars 2
Steve 1954 Sunbeam Alpine MK III Roadster on eBay Sunbeam (Rootes) 3
DonC1948 TR6 A "CLASSIC" question. Triumph 6
