TR6 TR6 Hayden Pusher Fan Wiring
J
JP72TR6
How do I wire up the Hayden fan in pusher mode - specifically the yellow wire that is for the "key on" connection? Can this wire go to a position on the fuse box? If so, where and how (any pictures)? I'm not looking to do a manual switch, just basic installation.
poolboy
"Key On" would be the White wire side of the fuse that protects the green wire circuits....
That means any time you have the ignition key in the ON/RUN position the yellow wire is going to get 12 volts...is that what you want ?
J
JP72TR6
Sounds right, I'll give it a try.
The instructions for the fan say, "Yellow Wire: connect the yellow wire to any key activated circuit. The yellow wire must be connected to a full and constant 12 volt source. Low and fluctuating voltage will cause early relay failure. Red Wire: connect the red wire to the positive wire of the battery."
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
