TR2/3/3A Calling all Wiring experts TR3 Overdrive Wiring ver A or ver B or are they the same?
luke44
I got my trans back from Quantum but when I went to wire up the OD I found in my records from 10 years ago a suggested wiring layout from TRF entitled “from 18913”. My car has the original screw on connectors and was wired per the TRF option 1 below which matched up with my subharness from British Wiring. but I also see option 2 which I posted years ago is different.
Do these 2 variations amount to the same thing? I’m assuming the TRF version has power to the switch which then switches the relay on at W1, sending power to the trans switches via W2.
This is the one more commonly seen but my old records seem to indicate TRF indicated a change at s/n 18913?
mezy
Both will work, it is just the first way the switch is before the relay, the second is after the relay,
The second option will put less stress on the switch, as the current is going through the relay first which acts as a resister.
I think the second way of doing it will prolong the life of the switch which is probably why it was done this way
luke44
luke44
Nice to have it confirmed, I’ve never taken a relay apart so wasn’t sure if W1 connected to W2. As I think back almost 10 years ago now, the sub harness may have come from TRF which led to the sketch above, can’t recall.
The sub harness wires are exactly as shown in the #2 TRF example, so for those come later it’s a reference to match up the wiring method with the harness you have. That’s possibly variable based on source/supplier.
CJD
While you’re working on it…Randall always recommended using a diode on the solenoid side of the relay, to reduce the high voltage spike across the relay contacts. That’s the main way to increase the relay life.
luke44
luke44
Thanks John, yes I saw that while researching the various posts. Debating whether to incorporate one while I wait for my 90 angle adapter to come in; I broke mine putting the trans cover on. :ROFLMAO:
charleyf
I recently installed a TR6 OD trans in my 59 TR3A. There was no need for a 90 degree angle drive. I just used the longer trans cable made for the OD units.
I did follow Randall suggestion regarding the diode. I also added a fuse where he suggested.
I also added a small indicator light on the dash to show when power is sent to the solenoid/ tranny is in OD.
Charley
DavidApp
If you do use the 90 degree angle drive watch for the added washer that should be added. I installed the longer cable on my OD so I did not need the angled drive.
David
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
CJD TR2/3/3A Calling all TR2 Owners! Triumph 11
trotti Calling all SU experts - Volvo HS6 Carbs Austin Healey 11
spudboy999 Calling all Jag 420 Saloon owners.... Jaguar 4
Frankenhealey Calling Cottontop - Quad SU Nasty Boy - Craigslist Austin Healey 3
Tr3aguy TR2/3/3A Calling the midwest..TR3 for sale Triumph 7
Tr3aguy Calling all Gearheads....HELP Triumph 14
bighealeysource calling any BN2 owners- room for top behind seats? Austin Healey 14
glemon Calling all Vacuum Experts Triumph 6
RJS TR4/4A Calling All TR4A's Triumph 15
AUSMHLY What model Healey is this...calling all Eagle Eyes Austin Healey 21
L Avon tires?? calling Reid and others... Austin Healey 5
W Calling all Jeep fans-got a wotisit? Other Cars 8
roofman Calling all Mini Guru's- What do I have here? British Motor Corp 6
T calling brosky Triumph 1
Banjo Calling all Jeep Junkies! Other Cars 9
Steve_S Calling for MG Holiday Photos! MG 4
G Calling North Carolina Healey Members Austin Healey 2
curtis Arizona calling Austin Healey 2
M Midget Diagnosis? Calling all Gurus MG 4
T TR6 Alternator wiring Triumph 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
J TR2/3/3A Wiring Triumph 11
T 1971 Fuse Box and Wiring Triumph 7
tahoe healey Wiring Diagram for Fog Lights Austin Healey 12
P Wanted Wiring scraps Triumph Classifieds 14
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
B Steering Column Wiring/Sealing Austin Healey 1
timsgolf Coil Wiring Austin Healey 20
T Spitfire 67 MK2 Wiring Triumph 12
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
P XJ12 Wiring diagrams Jaguar 1
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
B TR4/4A Basic Wiring Question Triumph 35
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
I Lotus Elite wiring diagram Lotus 6
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
6 BJ8 Headlamp Wiring Austin Healey 1
S MGB mystery wiring plug MG 2
R TR6 Starter wiring question Triumph 6
R Spitfire Turn signal wiring Spitfire Triumph 5
B TR4/4A High Torque Starter Wiring Triumph 9
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
J Wiring Harnesses Issues Spridgets 3
S Wiring Harness Replacement Spridgets 1
R Electric fuel pump wiring Spridgets 4
