Alright you MG Gurus. My beloved is a 74 Midget with the 1275 engine, and Weber DGV carb. Had a rough running engine, reduced power, intermitant backfiring, occasional gasping, irregular idle speeds, louder than normal sound from engine, etc. Had a tune up at Midas: new plugs, points, rotor, plug wires, etc. Checked timing. Came away still rough, but very pretty plugs and new wires. Then went to more reliable shop, where they scoped engine, replaced distributor, instralled Pertronix ignition. Now runs much smoother, and idle speeds seem more stable. But, power is still not what it used to be, and still have intermitant backfiring. WADAYA THINK I SHOULD TRY NEXT? Think the Carb needs a rebuild? The Weber was on it when I got the car 2 years ago. Could that create the sluggishness? Valve adjustment? The last shop listed a replaced valve cover gasket on the parts sheet, so maybe that indicates that they checked valve adjustment? Rings? No compression test listed in the labor description. You can no doubt tell that I am not a mechanic, so spoon feed me your explanation, if you want to take a shot. Your humble servant, Midgey in Albuquerque. /ubbthreads/images/graemlins/driving.gif
