TR2/3/3A TR3 Wiper motor wiring and testing
Joel Lester
Hey guys! Doing a frame off restoration on my '58 TR3. Getting closer to getting ready to re-wire the entire car. In the mean time I've been finishing up most of the stuff in the engine bay. I cleaned up the wiper motor, painted it and put it all back together. I figured I'd try to see if the motor works or not so I grabbed a 12V battery and put neg on one terminal and pos on the other - sparks is all I got! LOL! Then realized the neg goes on the screw that holds the cover on - sparks again!!
I then looked back at the old pictures I took when taking this whole car apart and noticed a black ground wire that comes off the wiring harness and goes under one of the mounting bolts for the wiper motor. So maybe it's not working because I didn't ground to the car?? Looking for some guidance on how I can test this before I get the new wiring harness (there isn't an inch of wiring on the car now).
BTW... this car has never ran since I got it - it was a "barn find" of sorts. I've been working on this complete restoration for about a year and a half. It's really looking good but from time to time I need to reach out to you guys for some help!
Thanks in advance.
Joel
Platinum
Joel Lester
Joel Lester
Thanks for all of that incredibly useful information Mike. I really appreciate it! I think I'll wait until I get the wiring harness and get it all wired up like it should be and go from there.
Cheers!
Joel
mt10flyer
I think the TR-3 has a single speed wiper motor. By coincidence I just worked on mine. There are two spade posts on mine. One is for the 12v coming off the switch (mine is converted to neg Ground) and the other is ground. What you did should be a good test so the wiper motor may be fried. I would remove it and bench test it for verification.
Popeye
Bronze
Let me know if you want my single speed wiper motor (I replaced it with a two speed.). It’s not been tested, but I took it apart and cleaned it and replaced the brushes. And I can’t vouch it fits in a TR3.
R TR2/3/3A TR3 Wiper motor Triumph 10
S TR2/3/3A grease in tr3 D2 wiper motor Triumph 2
S TR2/3/3A color of tr3 D2 wiper motor Triumph 5
S TR2/3/3A Wiper motor brushes tr3 Triumph 2
S TR2/3/3A wiper motor tr3 Triumph 4
mgedit TR2/3/3A Wiper Motor Bracket for 56 TR3 Triumph 9
mountainman TR2/3/3A TR3 Wiper Motor Triumph 4
P TR2/3/3A tr3 wiper motor mounting Triumph 7
mountainman TR2/3/3A TR3 Windsheild wiper Motor Question Triumph 4
Got_All_4 TR5/TR250 Switching a TR3 wiper motor over to a TR250 Triumph 4
M TR2/3/3A TR3 Wiper Motor Rebuild Triumph 8
martx-5 TR2/3/3A TR3 Wiper Motor Triumph 3
gsalt57tr3 TR2/3/3A TR3 Windsheild Wiper Motor Triumph 7
T TR2/3/3A TR3 wiper wheel boxes Triumph 5
S TR2/3/3A wiper blades tr3 Triumph 14
mgedit TR2/3/3A Wiper Wheelbox 56 TR3 Triumph 21
B TR2/3/3A TR3 Windshield Wiper Tubing Triumph 5
tinman58 TR2/3/3A wiper cabel TR3 Triumph 6
S TR2/3/3A wiper assembly tr3 Triumph 4
mountainman TR2/3/3A TR3 Wiper Switch Triumph 5
T TR2/3/3A Lucas/Peter Pan part two. [TR3 wiper] Thanks Triumph 3
martx-5 TR2/3/3A TR3 Wiper Box Triumph 7
S TR2/3/3A Tr3 wiper arms Triumph 0
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
