Marvel Mystery Oil
SaxMan
I've always been kind of a skeptic with oil additives, especially when the last one I tried raised the oil pressure so high, it blew out the seal on the oil filter. However, I did get some Marvel Mystery Oil when I decided to attempt to start the motor on the '53 Plymouth for the first time (The Plymouth did start and run...that Flathead six is an amazingly quiet and smooth motor). I was so impressed with the results in the Plymouth that I decided to try it in the Sprite. Holy cow! The motor felt stronger and revved smoother than I ever recall. Maybe some of it was the perfect weather conditions - 70 degrees, sunny and dry, but I couldn't believe how much zip the car had today. 2nd gear runs up to 4500 rpm were a breeze.
Considering that the motor rebuild is on hold while I'm working on the Plymouth, this was a good development. My question is, how often do you put the additive into the oil? With each oil change? Considering that the Sprite has automatic self changing oil every 1200 miles, give or take another 100 - 200 depending on how long the car sits (I tend to lose more through leakage than through burning), I'd assume after I put the fourth new quart of oil since the oil change in, I'd go ahead and put in the additive.
number6
My only experience with MMO was at school. There were two Ford flathead V8s that ran the rope tows and at the end of winter MMO was used to fog the motors down for storage. I think modern oils have all the additives needed. I also don't think that MMO is a VI improver, I am guessing it may very well thin the oil. I also remember seeing MMO used as a Top cylinder lube. People would mount a glass bottle of the stuff in the engine compartment and it would drip feed into the carb manifold to lube the valve gear.
JPSmit
I might spread it thinner than that. I use Lucas oil stabilizer but only during oil changes - I top off with regular oil.
My concern is that is you start with 75/25% oil/MMO mixture and then add a quart of MMO - you will end up (at least in that cycle) with 25% MMO (the quart) plus 25% (2/3 quart MMO (of three quarts) remaining in the crankcase) - at which point you are about 40%(?) MMO.
So, to my mnd, either, 1. only use it when you change the oil or, 2. make yourself a mix of 75% oil/ 25% MMO and use that to top off the crankcase.
Sarastro
I think it is indeed good to be a skeptic regarding additives, and I'd include MMO in that skepticism.
The people who formulate motor oil put a lot of knowledge-driven judgment into decisions about what components to use and how much of each. There are trade-offs in each decision. For example, an additive might make the engine run smoother, but above a certain concentration might cause problems, so its concentration must be limited. When you add an additive, you upset that whole apple cart. I don't doubt that some particular additive (like, MMO) might make the engine seem to run smoother, but what about all the other things oil must do, like preventing wear and corrosion? How does it affect those? You really don't know.
I'd use a good-quality name-brand oil in 10W-40 or 20W-50 grade, and leave it at that.
westfield7
I've always used it when I change the oil in the spridget gearbox. After I've drained the oil I run a pint or so through the 'box. I pour it into the box at the shifter housing and leave the drain plug out. When I raced that was always good to get a few extra bits of metal out.
mightymidget
MMO is used in all my gasoline power lawnmowers etc.. Ran it in a Club Cadet for probably 20 years. Also I have used the Lucas in some older cars.
Really can not give any scientific figures, all I can say since I was a kid 60 years ago it has always been for sale at hardware stores, parts houses, truck stops. Just saying.
Joe Schlosser
I Love the idea of a final flush of the trans by running light oil through the shifter housing. I will have to try it on my just rebuilt trans.
My previous technique was to fill and then tilt the trans up till I got flow out of the shifter and then let everything drain. This seems much better.
AN6-TX Application of Marvel Mystery Oil Spridgets 8
A Marvel Mystery Oil Austin Healey 18
af3683 Marvel Mystery Oil Triumph 24
K TR2/3/3A Mystery TR Part Triumph 9
Celtic 77 MGB Mystery cylinder head attachment. MG 4
A For Sale Mystery brass intake manifold Other British Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
equiprx Mystery part Other British Cars 2
BoyRacer Austin A90 mystery engine British Motor Corp 2
V MGB Mystery fastener from '66. Did I miss something? MG 6
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
BoyRacer Mystery 3000 Engine Block Austin Healey 2
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
D TR2/3/3A Another mystery part(s) Triumph 2
S MGB mystery wiring plug MG 2
jehuie Morris Minor horn mystery British Motor Corp 12
D TR2/3/3A Another mystery part Triumph 8
Sixpack TR6 Horn Mystery Triumph 3
M TR6 Mystery Switch Triumph 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
J TR2/3/3A TR3 gas tank mystery Triumph 5
M TR6 Fuse box wiring mystery Triumph 9
S MGB mystery wire MG 32
somewhatspritely Mystery Screws Spridgets 5
Healey Nut Mystery Part Austin Healey 2
D TR2/3/3A Another mystery part..or two Triumph 14
B 2013 Nissan Frontier front end mystery Other Cars 7
B MGA Mystery bolts MG 2
P Mystery Lexus?? Other Cars 10
T New Generator Mystery Austin Healey 5
B MGA Mystery MGA chassis part MG 3
K TR2/3/3A Mystery stall and no start? Triumph 7
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
J TR2/3/3A Mystery Wood Triumph 7
K Mystery badge bar Other Cars 4
P Mystery Car Other Cars 11
Y MGB A bellhousing mystery.... MG 3
P Mystery leftover BJ7 Pieces Austin Healey 18
warwick-steve Mystery Rattle Austin Healey 21
K Off Topic Mystery Windshield Brackets or ?? Triumph 6
warwick-steve Misfire mystery Austin Healey 28
ckeithjordan TR2/3/3A TR Mystery Thingy Triumph 13
D mystery Friday... Austin Healey 5
D mystery of the day... pedal block? Austin Healey 5
HighAltitudeTR3 TR2/3/3A Mystery Bracket Triumph 23
D TR4/4A water pump mystery hole Triumph 6
P TR6 Purple/Red wires & mystery bulbs Triumph 17
T TR2/3/3A Another Mystery Part Triumph 8
R TR2/3/3A Mystery part? Triumph 10
