Braided Wire Insulation
memphis
Hi Guys!
I am looking for a few feet of stock braided wire insulation for the license plate light and for the fog lamps.
Does any one know what vendor carries a close match for our Healeys? I looked at the Moss, Vic Brit, and Englishparts sites and didnt see any?
Any suggestions are appreciated.
Thank you!
Bob
p.s. Also looking for caps, protectors for the electrical connections to the front lamps inside the wheel wells. Mine are currently exposed to the elements.
PAUL161
Bob, look for an old established business for repairing electric motors. If they've been around since the 50s, they might have some old stock braid covered wire. Most all wire today and for the past 30 years is vinyl wrapped. PJ
AUSMHLY
memphis said:
Hi Guys! I am looking for a few feet of stock braided wire insulation for the license plate light and for the fog lamps.
Thank you!
Bob
Hi Bob,
Moss carries rubber connectors, #19 & 20, if this the type of protectors you're looking for.
If you're searching for the cloth type braided wire insulation, the places listed by Paul & Big6 should be able to help you.
If you're looking for the black tubing that protects the wires coming out of the boot for the license plate, you may find black vinyl tubing or shrink tubing at the local hardware store will work.
Some places like Frys electronics carries 4 feet long tubes of shrink tubing in various diameters. Get the diameter you need and don't shrink it if you don't need too. Click Frys shrink tubing
Good luck,
Roger
Keoke
:savewave:
All the previous comments properly address your problem.
However Bob,Cosidering reliability, I would not use that cloth type wire in the applications you have cited.
Modern Plastc insulated stranded wire is a much better choice and should also be enclosed in the black plastic conduit.
-----------------Fwiw--Keoke
JPSmit
somewhere recently someone talked about using hockey skate laces for a very effective braided cover for wires
Keoke
I didn't see that one JPSmit, but if they are cloth like other shoe laces I would not recommend they be used. Preferably in these applications I suggest a wiring circuit that is highly resistant to absorbing moisture.--Keoke
JPSmit
They are (I think Polyester)
Healeysince59
The "Modern" cloth covered wire as provided by British Wiring is PVC insulated the same as any modern wire and the cloth cover is for appearance. If you find some old stock cloth covered wire, it's going to be insulated with 50+year old rubber and cloth. I wouldn't use it.
Marv J
Keoke
You are probably right Marv. However, what may not be common knowledge is that Plastic insulation on most electrical wire is not homogeneous.
For Military Purposes we specify the quality and test the wire to insure it complies.
When you put a moisture retaining cover over regular plastic insulate wire there is the possibility over time of moisture attacking the wire via the porosity of the every day type plastic insulation.--Fwiw--Keoke
If you're just doing short runs or simple repairs (in popular solid colors), any electrical supply house can provide you with HTML wire, in a variety of gauges. High Temperature Motor Lead has a woven glass fabric outer cover over a silicone rubber primary insulation. The conductor consists of many-many fine tinned strands, making it also very flexible, besides heat resistant.
Besides working with it for electrical controls, sensors & motors, I've also used it when working with O2 sensors on cars.
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
SD Bugeye HS2 interconnecting SS Braided fuel hose Spridgets 7
J Fitting 5/16" Steel to 5/16" Braided SS Rubber Fuel Line Austin Healey 4
K TR2/3/3A SU Braided hose Bling? Triumph 6
NutmegCT braided fabric fuel line cover Restoration & Tools 8
coj Braided fuel lines 29 f engine Austin Healey 2
T Oil Pressure Gauge braided line failure Austin Healey 6
98Redline BJ8 Stainless Braided Brake Hoses Austin Healey 8
DNK Braided Lines MG 4
J Braided ground cable Triumph 3
G A word of caution about using braided hoses..... Triumph 15
T Braided steel brake lines - worth it? Triumph 13
S Steel braided fuel line Spridgets 7
jhorton3 Braided Oil Pressure Line Spridgets 12
davidk TR6 Braided Steel Brake and Clutch Lines for TR-6 Triumph 1
SCguy Braided Steel Brake Lines with Toyota Caliper Triumph 19
G Braided Stainless Steel Hydraulic Hoses Austin Healey 15
A Cutting S.S. Braided Hoses Triumph 4
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
K TR2/3/3A head gasket repair wire Randall Triumph 1
Todd78d Wire wheel cleaner Spridgets 1
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K 1068 mkIII wire wheel rub Spridgets 1
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
W TR2/3/3A Wire Wheel Conversion Triumph 5
SNClocks Electrical Wire Lug Spridgets 2
R Wire Wheel Fit Austin Healey 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
KLUTZ Wedge FASD wire question Triumph 1
P TR5/TR250 Wire wheels width Triumph 8
P Wire Wheel Splines Austin Healey 10
KVH General Tech O/D Electrical Wire Burned Triumph 22
D Wire Wheels and Air Leak Austin Healey 16
S TR2/3/3A wire repair Triumph 7
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
R General TR Emergency hot wire - because you never know whats next Triumph 2
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
S MGB mystery wire MG 32
RJS General TR Wire Wheel Spline Question Triumph 3
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
steveg TR6 Steering boot clamp wire - why? Triumph 2
